My Project: TSX Projector Retrofit Review! Lots of pictures :).
#48
I'm about to do mine myself... I got the projectors, Now I just need a bit of time. Now I know how to modify the projectors and I have the dremel to cut the tsx's to fit right in there. I already retrofitted tsx's on my accord and i liked it, used it as a test mule before I jumped in the evo. Now I know what to expect with my accord and even more with this write-up.
#49
If anyone needs projectors let me know. I can probably score some. There's two different kinds of tsx's projectors. The newer models are "fresnel", which have rings around the projector lenses and there are "water clear" which are the ones you want for this. The fresnel style don't have that sharp cut-off line like the clear version.
#56
If you knew anything about projectors you would know that the evo projectors are the best ones out next to TL's then TSX. The evo one's are the same ones used in alot of supercars even used in the FXX the first one made.
#58
