Emblem overlays?
Just head down to your nearest sign-store or graphic design shop and have them print you out some. Just create a vector square, rotate it 45 degrees. Measure the tip of the emblem diamond to the base tip, then make the vector square that height. Noe measure tip to tip across the diamond and make the vector square that width. Print on a vinyl plotter (they all should have one, if not go somewhere else). Call it a day. I have a whole sheet of all different colored inlays for my rear diamond emblem, created this way for about 3 dollars and an intresting conversation.
