Show yor Valentine 1's!
#32
About the setup:
that f*ckin sick. I gotta get that. Especially here in VA where radar detectors are illegal. That setup is just perfect.
#33
Why would an officer pull you over? Is it illegal in your state? I believe radar detectors are illegal only in 2 states, one being Virginia.
About the setup:
About the setup:
#34
Fortunately, I had another one in another car and I've been transitioning it back & forth depending on which car I'm in.
#35
About the setup:
About the setup:
#39
It was mentioned that the V1 might not pick up laser from where it is mounted in the rear deck... this is negligible because if you are picking up laser with your V1 and you are speeding, chances are the LEO will be pulling out behind you regardless of how much you brake because you are caught!
#44
#45
