Full Flat-Bottom Undertray EVO
Old Jun 15, 2008, 11:52 AM
nils's Avatar
very cool.... too bad that is illegal for time attack street class.
how much does it all weigh?
n
Old Jun 15, 2008, 11:53 AM
Johnboy1065's Avatar
looks pretty cool, I've been thinking about trying to get an undertray for mine. I just don't know of any that might fit with my ams turbo kit downpipe. also I'd have to have one that has a hole cut for the open wastegate. or just cut one myself. but this thing looks good
Old Jun 15, 2008, 11:54 AM
jmartinez1170's Avatar
Its about time some one made one of theses ive been thinking about doing one for so long. Without the car running i put it aside. Im gald somone did one. PM price once all done.
Old Jun 15, 2008, 02:38 PM
jid2's Avatar
n
Not that much, I'd guess between 10-13 lbs. The side-skirts maybe legal... You know you want to step up to a higher class anyway!
as for jack points the rear ones are accessible, that's were the stands are. Up front I always jack from the boxed frame, which is still usable although the side skirt is attached there, it's no problem. If you look at the first picture it shows a large window cut-out so jackstands are still usable on the body seam.
Old Jun 15, 2008, 03:13 PM
TheBlueBlur's Avatar
I have the beatrush undertray right now, and its great. I'm still interested in a rear diffuser though.
Old Jun 15, 2008, 03:43 PM
JDMevoBOOST's Avatar
I think you have to worry about increased heat to the driveshaft, oil pan..
Old Jun 15, 2008, 03:52 PM
hotrod2448's Avatar
As others have said you need to be aware of the additional heat this will retain. If you have the ability I'd get some louvers or NACA ducts in there.
Since we've gone to the splitter's on the front of our race cars (no undertray's even) the heat in the engine bay has increased dramatically. You seriously can't touch anything in the engine bay with out burning yourself.
You might want to throw some temp strips on things like the gas tank and driveline to see what temps they are reaching. Like these:
http://www.drypak.com/media/images/THERMAX-dist.pdf
Old Jun 15, 2008, 04:57 PM
kmcconn9's Avatar
very interesting stuff...
Old Jun 15, 2008, 05:03 PM
tabio42's Avatar
Can you make those plastic panels so that they don't stick out past the sideskirts?
Old Jun 15, 2008, 05:04 PM
spraa's Avatar
Very interesting indeed...I really like the idea.
Old Jun 15, 2008, 05:53 PM
inco9nito99's Avatar
Price please? :P.
Old Jun 15, 2008, 09:35 PM
jid2's Avatar
That would be against the idea of using them. They stick out so that the air under the car doesn't escape to the flow around the car and vise-versa.
Things are not far enough along for a price just yet. The side-skirts are pretty straight forward, they simply bolt on and require no modifications. I have a place that CNC's them and the fit and finish is fantastic, plus the pricing is decent. And I have a fancy way to ship them so it doesn't require freight, they can go UPS.
The center undertray is also a direct bolt-on, no mods required. But I don't see a way around freight shipping. I don't know if the volumes, ie. you guys buying them is enough to warrant having them built for me, it's hard to know. I could build them myself, with my tools, but the fit and finish wouldn't be what I typically like for production. Having them manufactured would be pretty expensive I fear.
And the extension to the APR splitter requires either welding on mounting point to the chassis braces, or me supplying new chassis braces. If I supplied the chassis bracing the price would be much higher.
Your guys thoughts?
Old Jun 15, 2008, 10:05 PM
TheGVR4kid's Avatar
Any thoughts on flaring the rear of the front undertray upwards to create some low pressure for the front axle?
Old Jun 15, 2008, 10:36 PM
Dorikun's Avatar
Remember heat rises! So what they say about engine temps and gas temps is true. You wouldn't want your... seat bottom to catch fire. (putting it nicely)
Old Jun 15, 2008, 10:59 PM
EVOIXMR8916's Avatar
Originally Posted by YellowEvilEvo
How do you counter the extra heat that is going to build from the metal and the exhaust? I am just curious. It looks awesome. Keep us posted.
well thats easy even for me to answer... you want heat in the exhaust system because hot air has more velocity and therefore exits faster...and your t-case and tranny are still cooled down by the air coming through the front...very Simple....lol
Quick Reply: Full Flat-Bottom Undertray EVO
