Polishing Aluminum
Old Sep 3, 2008, 02:13 PM
smoke777x's Avatar
Polishing Aluminum
Hey guys, I ran in to this site a while ago and just tought some people might want to know how to polish aluminum. So here ya go...
http://mr2oc.com/showthread.php?t=23...olish+aluminum
Let me know if you have to register to view it, if you do i will try to copy the stuff and post it.
Old Sep 3, 2008, 02:16 PM
jpetro10's Avatar
Old Sep 3, 2008, 07:23 PM
smoke777x's Avatar
I get a lot of questions concerning my polished engine pieces. I think it's time to reveal the big secret (which is that there isn't one)! I took pictures of all steps needed to get from a standard >10 year old part to a shiny mirror-like show piece. I also wrote down the amount of time needed to complete each step. Now let's have a look!
We start with the standard piece, in this case it's the coolant neck of a Gen3 3S-GTE engine.
The first step is the most time consuming and important phase. The amount of work and detail you're prepared to bring into this phase determines how well it'll look in the end.
To get the part to a smooth, mirror-shine finish we need to smoothen the surface of the part. Since this aluminum part is cast, the cast structure needs to be leveled. Aluminum is very soft and this can be achieved by hand-sanding the structure down with grit 80 sanding paper:
I'm using a cork sanding block, which isn't too large and gives in a little. A hard, plastic sanding block wouldn't work as well because it's not flexible, making it much harder to sand curved surfaces.
After the first stroke, this problem area becomes visible:
The top is not completely round but has a weird shape. You could leave it like this, but as I said, this stage determines how well the finished piece will look. So I want this removed to create a nice round shape instead of what it is now. I use a big metal file to level the high areas. This is the result:
I also filed down the casting seams at the top:
The rest of the shapes were okay, these just required sanding. Do as much as you can with the sanding block, because you can easily apply pressure on it, making the work much easier. Also, when not using a tool like a block, you're bound to create waves in the soft material, which will show once it's completed. Compare it to body filler: you need the sanding block to create a tight, planar surface. If you'd sand the filler by hand, you'd create a warped surface.
After sanding more:
Here I filed away the ongoing casting seam with the same file:
The file leaves pretty heavy scratches. 80 Grit sandpaper deals with it though:
A bit further down, there's a small '2' cast into the piece.
I used a miniature file to get rid of it:
I used the large metal file again to level this:
You can see how much material was removed by looking at the blank material. After more sanding, sanding and sanding, stage1 was completed.
TIME NEEDED TO COMPLETE 80GRIT SANDING: 6-7 HOURS
The next stages are considerably shorter, and easier. 120 Grit sandpaper is up!
In this picture, the top part has been sanded down with 120 grit, the rest is still 80. The idea is, that every scratch you made with the 80 grit sanding paper must be removed by the 120 grit. If you don't, you'll see it throughout the remaining stages!
Here, the piece is complete done.
TIME NEEDED TO COMPLETE 120GRIT SANDING: 1.5 HOURS.
The next stage is 220 grit sanding. Again, you should sand away all the sanding marks left by the 120 grit stage. All done:
TIME NEEDED TO COMPLETE 220GRIT SANDING: 1 HOUR.
Ilpoto is offline Report Bad Post Board Rules, Help with posting, Vendor Help and Rules Reply With Quote
The next phase it 400. This is where it gets tricky, because this is one of the highest grits you can still dry-sand. Wipe off the paper often, because it tends to fill up with aluminum dust very quickly.
As you can see, the piece gets shinier by the hour!
TIME NEEDED TO COMPLETE 400GRIT SANDING: 1 HOUR.
Now we move to wet sanding. Get a bucket of warm water and throw in some pieces of 1200 grit sanding paper. You might also get an old towel, fold it four times, and lay it on your lap. I found this greatly helps in not getting my lap soaking wet.
lso, note that at this point, sanding can be done by hand for most parts. You're not altering the shape of the piece any more, you're just refining the texture of the aluminum. Some parts may still be easier to do with a block or rubber, but hand-sanding will get you into all the tight areas.
TIME NEEDED TO COMPLETE 1200GRIT WET-SANDING: 45 MINUTES.
The last sanding step is 2500 grit. Again, this can be done by hand to save time. Finished piece:
TIME NEEDED TO COMPLETE 2500GRIT WET-SANDING: 45 MINUTES.
Now it's time for the topping on the ice! Get yourself a hard cotton/cloth polishing disc with polishing paste (usually a hard bar), and mount it on a drill.
Use this to polish the piece to the mirror-shine you always dreamed of!
TIME NEEDED TO COMPLETE MACHINE POLISHING: 15 MINUTES.
Old Sep 3, 2008, 07:26 PM
smoke777x's Avatar
Once again people, I did not do the write up. It was from a guy on mr2oc.
So thanks to him, lol.
Old Sep 3, 2008, 07:43 PM
SRT-TO-EVO's Avatar
Wow that's awesome. Where would you get a polishing tool like that?
Old Sep 3, 2008, 07:47 PM
smoke777x's Avatar
Well, when i did mine i got the polishing wheel from home depot for like 10 bucks for a set of 4 or something like that, and the sand paper you can get pretty much at any auto shop like pep boys or autozone.
Old Sep 3, 2008, 07:48 PM
smoke777x's Avatar
By the way the polishing wheel can be put on a regular drill.
Old Sep 3, 2008, 07:51 PM
xxxevo8xxx's Avatar
so much work.
Old Sep 3, 2008, 08:31 PM
soontobe's Avatar
hell of a lot of work, but bottom line holy ****...this is amazing!
Old Sep 3, 2008, 08:37 PM
Saikou_kun's Avatar
Damn! that is alot of work... but kudos !
Old Sep 3, 2008, 10:18 PM
LuisIX's Avatar
wonder if the stock ix enkies can be polished like that. i really like the look of the stock rims but the silver is played out....
Old Sep 4, 2008, 11:36 AM
smoke777x's Avatar
I was thinking about doing that ^^^. You would probably have to use aircraft paint remover first so the paint would come off. But then again its a lot of work so i just bought the SE wheels, lol.
Old Sep 6, 2008, 12:08 PM
groundzero1v's Avatar
where can you get that bar? and what is it called?
Old Sep 6, 2008, 12:51 PM
1badgsex's Avatar
polishing alum is not hard at all the sanding in "stages" is the hardest part i used to do alot of 1g eclipse and talon valve covers, i would shave all the letters lines off of it and polish it till it looked like chrome!!!!
Old Sep 6, 2008, 03:24 PM
andreww238's Avatar
thats sick.. did one of my dsm valve covers
Quick Reply: Polishing Aluminum
