Show Me Your Enkei's
#309
I've been told by a fellow evo owner that a 17x10 +38 will contact the rear trailing arm. Can anyone confirm this? What would then be the best size spacer to run if this is true? Also wondering if any fender work will need to be done. I also would like to know what is the minimum spacer size needed up front to clear the brakes as I want to stick with the smallest spacer possible
#313
not sure if you want pics of enkeis on an earlier model but heres mine through the 13 different sets of wheels I've gone through a couple of different enkeis
In the pics are 17 x 8.5 +38 Enkei Tarmac in white, 17 x 9 +22 Enkei RP01's in Black with Blue Ring and 17 x 8 +38 Stock Evo 8 Enkei's.
Currently have some 18 x 9.5 +15 RPF1s in Matt Black about to go on will post those new pics when they are on
