The AMS Drag Car clone build!
Aside being a few lbs heavier, this car should be every bit as fast as the drag car. It has the same engine, head, turbo kit, rear end, driveshaft, trans, transfer case, clutch, staging brake, etc.
This car is actually going to be SO much nicer and safer than the drag car.
Nice build guys!
One question though, the roll cage seems to be an interesting design. The bar that goes thru the top of the front dash, I usually see that bar extend all the way back and welded to the main hoop behind the seats. I'm not sure on the design of welding it at the top of the A-pillar. Almost ALL the cages I've ever seen are never in this design. It seems to be taking the easy way out.
Not sure, maybe a drag cage is supposed to look like that, but I know 99% of road racing cages I've seen would never be designed like that.
