CBRD- back in the saddle again...
#31
it will be stickered and registered (not required for the rules)...
and there are quite a few misc bolts that need to go on...
and for those that commented... we dont have the rad in yet... we built two rads.... we have to build mounts for the final version.... (which we have available now for clients, but at the cost of 895.00)
cheers
cb
#35
car will be running in modified and possibly unlimited...
Advan is supplying us with R comp's and slicks to test and evaluate...
cb
Car has stoptech 355mm 4 pistons on it now up front...
an OEM brake supplier called us last week, so we are negotiating a switch if they are aggressive enough....
cb
#40
As much fun as working on cars is all the time one might go crazy if they did not get a chance to race them. Glad to see you will be able to spend some time getting back to what you enjoy. Good Luck from what I have read the competitions going to be tough.
#45
Take a step back and snap a picture for F's sake! let's have a look at this thing.
Good to see it nearly done. Should be great when you guys start it next year after you get a last minute sponsor change on the oil filler cap and need to pull the whole motor to swap it out
