Chargespeed Evo....then vs now
#182
They don't, no. They are both Chargespeed front and rear bumper cars with RE30's, but otherwise are quite a bit different in most areas.
Write Chargespeed and tell them of your displeasure with the kit. Thanks for the constructive commentary.
#183
look something along the lines of this but i have mine mounted a inch higher so the right suction cup fits up against the dot matrix. your cars are all so well put together so i think its almost mandatory you do this. the telephone cord is just so wack haha
#184
you have my favorite engine bay man. if i were to dress mine up it would look exactly like yours. unfortunately anything but a completely stock look will get you owned by the smog refs here in CA. i especially love the brushed theme throughout. keep it up!
#188
Not feeling the kit, and the tails. I personally would've just sold the ARC cover, and got a stock one and powdercoated that.. instead of anti-JDM'ing a JDM part. Did you powdercoat the wheels as well?
#190
Thanks.
#192
Going through another series of mods......here is the updated mod list, with more pics to come soon!!
Engine:
Fully Built 2.3L Stroker
Fresh Core
Fully Sleeved Block by Darton
Crower 4350 Pro Series Billet Rods
ARP Rod Bolts
Crower 9310 Wrist Pins
Crower 4340 billet steel crankshaft 102mm stroke
CP Forged 9.5:1 Pistons
Crower Plasma Rings
ACL Race Bearings
ARP Main Bolts
Balance Shaft Eliminator
Buschur Racing Stage 3+ race head
Fresh Core
Ferrea dual stainless steel valve springs
Ferrea titanium retainers, locators, and locks
New Valve Seals
Custom BR Bronze valve guides
Supertech Nitride Coated Intake Valves
Supertech Nitride Coated Exhaust Valves
Stainless O-ring around each combustion chamber
Complete port & polish
New Bronze Valve Guides
ARP L19 Head Studs
Virtual Works Racing Aluminum Intake Manifold
Boomba Racing Billet 75mm Throttle Body
4 inch Aluminum Virtual Works Intake
AMS front and side engine mounts
ARC Radiator Cooling Panel
Black Powdercoated Valve Cover
Billet Timing Tensioner
818 Billet Power Steering Cap
Sparktech COP Pro CDI-12
HKS 280/280 Cams
HKS Adjustable Cam Gears
Boomba Racing Billet Aluminum Pullies
Fluidampr Harmonic Balancer
Power Enterprises Kevlar Timing Belt
Power Enterprises Kevlar Accessory Belt
Fuel:
AMS Fuel Rail
AMS Fuel Lines
Fuel Lab Fuel Pressure Regulator Black
Bosch High Impedance 2000cc Injectors
Buschur Racing Double Pumper
Twin Walboro 255 Pumps
Design Engineering Triple Threat Nitrous/Purge System
Design Engineering Bottle Heater
Exhaust:
Greddy Ti-C 80mm Cat back Exhaust System
Virtual Works Racing Stainless Downpipe
Turbo + Cooling:
Virtual Works Racing Coated T4 Race Header
Tial Polished 44mm Wastegate
Precision 6262 Dual Ball Bearing Billet Wheel Turbo
DEI Titanium Turbo Heat Shield
Extreme Turbo Systems Black Anodized 4 inch Intercooler
Virtual Works Modified Intercooler End Tanks
DEI CryO2 Intercooler Sprayer Kit
Virtual Works Custom Stainless 3.5 inch Intercooler Piping
Virtual Works Stainless Intercooler Pipe Strapping
Tial 50mm Polished Q BOV
Virtual Works Upper Radiator Hard Pipe
Virtual Works Lower Radiator Hard Pipe
Fluidyne Aluminum Radiator
Mishimoto Race Thermostat
ARC 1.5 bar radiator cap
Spal 10 Inch Low Profile Electric Fan
Virtual Works Custom Aluminum Overflow Can
Virtual Works Custom Aluminum Breather Can
Virtual Works AN Fitting/Braided Hose Breather Kit
Powdercoated Radiator Tie Downs
AMS 25 Row Oil Cooler
Spal 5.6 inch Oil Cooler Fan
Transmission:
Shepherd Racing Stage 1
New throwout bearing
New clutch fork, pin and return springs
New speedometer gear and sensor
New slave cylinder and line
REM ISF process (sliders)
REM ISF process (gearset assembly)
Double synchro 5th gear option
Shepherd Racing Stage 3 Transfer Case
Quaife LSD front differential
8mm to 10mm bolt upgrade
New seals and o-rings
Reshimming
Neodymium magnet
REM ISF Process
New ring and pinion with bearings
Shepherd Racing Rear Differential
Cusco LSD
REM ISF Process Ring + Pinion
Buschur Racing Rear Moustache Bar
Buschur Racing Rear Billet Side Diff Mounts
Drive Shaft Shop Level 5 900HP Rear Axle/Hub Kit
Exedy Wasabi Triple Ceramic Clutch
Hyper Multi Plate
AWD Motorsports Aluminum Driveshaft
Buschur Racing Driveshaft Loop
Works Short Shifter
ARC Titanium Shift Knob
Kartboy Shifter Base Bushings
Kartboy Billet Shifter Bushings
Suspension:
Tien Monoflex Coilovers
ARC Front Strut Tower Bar
Cusco Rear Strut Brace
Cusco Front + Rear Sway Bars
Cusco V1 Lower Arm Bar
Wheels:
Volk Racing RE30 18x9 (black gloss powdercoated)
Volk Carbon Center Caps
Advan Neova AD08 265/35/18
Volk Racing Duralumin Lugnuts (black)
Brakes:
Endless Racing 6 Piston Race Front Brake Kit
Endless Racing 4 Piston Race Rear Brake Kit
Endless Stainless Covered Teflon Swivel Brake Lines
Endless Brake Pads
Zeal Slotted Rotors
Interior:
Rexpeed Carbon Fiber Dash
Custom Carbon Fiber Shifter Console
Custom Carbon Fiber Glove Box
Rexpeed Carbon Steering Wheel Gauge Pod
Rexpeed Carbon A-Pillars
Ralliart Aluminum Door Sills
Mitsubishi OEM MR Carbon Fiber E-Brake
Tyrant Carbon Armrest
EVO SE Leather/Suede Seats
Black Suede Wrapped Evo 8 Steering Wheel
Mitsubishi JDM Double Din
Orbital HVAC conversion kit
Electronics:
Kenwood DNX8120 indash Nav/DVD
Rockford Fosgate Dual Amps
Boston Acoustics Front Mids
Boston Acoustics Front Tweeters
Boston Acoustics Rear Speakers
Boston Acoustics 10 inch Subs w/custom Fiberglass Enclosure
Greddy EGT gauge
Greddy Oil Temp gauge
AEM Boost gauge
AEM Wideband AFR Gauge
AEM Stand Alone EMS
AEM 5 Bar Map Sensor
Exterior:
Chargespeed Vented Carbon Hood
Chargespeed 20mm Front Fenders
Chargespeed Carbon Vortex Generator
Chargespeed Type 1 sideskirts
Chargespeed Type 1 front bumper
Chargespeed Type 1 rear bumper
Chargespeed Rear Carbon fiber diffuser
Rexpeed Ganador Carbon Fiber Side Mirrors
Rexpeed Carbon Fiber J-Panels
Rexpeed Winglet
Rexpeed Carbon Fiber Type-3 Trunk Wing
Mitsubishi Carbon Fiber Evolution VIII Trunk Emblem
Hyboost Performance Edged + Tinted MR headlights
Hyboost Performance Tinted taillights
Hyboost Performance Smoked Side Markers
Dafarmer LED License Plate Light
Custom Apex Silver w/ slight blue pearl in paint
Mitsubishi EVO MR Headlights
Evo XI Wing
Engine:
Fresh Core
ARP Rod Bolts
Crower Plasma Rings
ACL Race Bearings
ARP Main Bolts
Fresh Core
New Valve Seals
ARP L19 Head Studs
HKS 280/280 Cams
Fuel:
AMS Fuel Rail
AMS Fuel Lines
Exhaust:
Turbo + Cooling:
Transmission:
Reshimming
Neodymium magnet
REM ISF Process
Cusco LSD
Hyper Multi Plate
Works Short Shifter
Suspension:
Wheels:
Brakes:
Endless Brake Pads
Zeal Slotted Rotors
Interior:
Electronics:
Greddy EGT gauge
AEM Boost gauge
AEM Stand Alone EMS
Exterior:
Rexpeed Winglet
Evo XI Wing
