Evo 8 Tails Converted to 7's
Old May 19, 2009 | 01:19 AM
sphinxof2006's Avatar
So basically im too cheap to pay up the A$$ for some real Evo 7 Tail lights so i followed a write up on here and here is what came out
The write up i followed:
https://www.evolutionm.net/forums/ev...olution-4.html
Masked them off.
1st Coat of Krylon Red Stained Glass Paint.
Did a second coat to make it a little deeper red...
I asked my good friend Freddy, who helped paint and did body work on the L from GST Motorsports, to shoot the clear on my lights for me. 3 coats of professional clear.
After a night of drying no buffing or sanding they came out CLEAN in my opinion
Old May 19, 2009 | 01:30 AM
xspsi4's Avatar
Wow nice!! I am going to do this next week, I guess I will put on pro clear though.
Old May 19, 2009 | 01:39 AM
xspsi4's Avatar
Also what kind of tape did you use to mask the lines?
Old May 19, 2009 | 01:42 AM
URBANRCR's Avatar
Just looks like painters tape cut into strips the appropriate size. Good job with the tails
Old May 19, 2009 | 09:56 AM
i used pin stripe tape i got from a auto body supply store it was 1/8 inch in width i had to use two strips per a line overlapping and it took around 2 hours to mask both off since i wanted it perfect. and my eyes hurt afterwards lol. yea that clear made it look great because without it, orange peel look is what they would turn out like. Thanks guys!
Old May 19, 2009 | 06:50 PM
EatSleepBoost's Avatar
i had mine like this before with the same paint but have since removed it and switched to black vinyl.
The only thing u gotta watch out for is fading. mine became pink after about 3 months. a few good coats of clear like the OP stated should be sufficient however. Be sure to use a good clear
Old May 19, 2009 | 10:11 PM
bricel24's Avatar
That's awesome! Are you on EvoEmpire.org by any chance?
Old May 20, 2009 | 12:28 AM
yea my name on there is mrevo8 all lower case. i seen someone else with all upper case MREVO8 not to be confused with me!!!
Old May 20, 2009 | 12:29 AM
how many coats and what kind did u have on yours?
Old May 20, 2009 | 12:38 AM
Donny's Avatar
looks good, I have the genuine 7s and yours look identical
Old May 20, 2009 | 12:54 AM
Thanks! it was worth the 20 bux i spent hehe i got hooked up on the clear,Thanks freddy!!!
Old May 20, 2009 | 01:08 AM
Heisman80's Avatar
Cool way to mod it on your own. as long as ur happy with the end result thats really what matters most.
Old May 20, 2009 | 06:28 AM
BEISSEN's Avatar
Not bad that looks really nice.
Old May 21, 2009 | 07:06 PM
mine that faded had 2 thin coats of clear. not sure what kind the clear was however but it was out of an aerosol can. If i was every to do it again i would bring it to my body shop and have them just spray a few coats of the good clear on there and it would last for a long time.
Old May 21, 2009 | 08:05 PM
MOREPSiTEHBETT4's Avatar
damn, the rear end you got is clllllean! the last pic is the w1n
Quick Reply: Evo 8 Tails Converted to 7's
