Supreme Power Super white H11 Bulbs installed...WOW!
Old Oct 20, 2003, 01:33 AM
BadBoyBeltran's Avatar
for all of you who bought these bulbs, did they last long(both 55W and 80W)?
Thanks.
Old Oct 20, 2003, 12:37 PM
lil'evil_evo's Avatar
Whoever got them I'm sure nobody has had then long enough to tell how long they will laste. We all just found out about the H11's about a month or 2 ago.
Old Jul 17, 2004, 11:52 PM
trinydex's Avatar
how about posting them yellows?
Old Jul 18, 2004, 06:59 AM
tx evo's Avatar
How about some installing instructions?
Old Jul 19, 2004, 01:49 AM
Mevolution2002's Avatar
Damn those look good. Just to make sure, you changed the HID bulbs and the fog light bulbs right?
Old Jul 19, 2004, 11:16 AM
EVIL VIII's Avatar
I ordered mine today...I got the 80 watts in the super white. The yellows didn't seem too...YELLOW!! How are the bulbs holding up now for most of you guys who have had them since October/November? Thanks!!
Old Jul 19, 2004, 11:40 AM
v8killer's Avatar
I have some, and run my fogs alot. I have the 55 watters, which are very bright. I have had no problem. But they are not as white as they used to be it seems. At first they where whiter than stock HID, but now they are a little yellow. I have had mine since about December 03
Old Jul 19, 2004, 11:49 AM
EVIL VIII's Avatar
Cool...thanks for the info. I ordered the 80 watts pair. The website said that both sets (55 and 80 watts) were 5000 degrees, so melting my light housing isn't a concern really. Plus, I had 80 watt bulbs in pretty much all of my previous cars, the lighting performance is much better, that may be way yours seem more dim now, but that could be you just being used to them now...
Old Jul 19, 2004, 01:25 PM
eclipsegs2k1's Avatar
i've had mine since december, i got them from europeanautosport.com and have been very happy with them. They are whiter than the HID's similar to what the first guy posted... installation is very straightforward, i just looked in the evo owners manual and it had pictures and some text about what to do, the only hard part is fitting your hand down and just getting the old ones out.
Old Jul 19, 2004, 01:43 PM
pwrd_by_diznutz's Avatar
looks good
Old Jul 21, 2004, 08:20 PM
trinydex's Avatar
how do you install these? i don't even know how to start.
Old Jul 25, 2004, 03:31 AM
trinydex's Avatar
ok check it out, i got these, they're great, you don't even need to ge the 80 watts to make them match, the match is wonderful and now i'm starin' down the street with 4 bulbs all the time (before i was ashamed to turn on my fogs cuz they were yellowy :[)
install goes as follows: the fogs are easy on both passenger and driver sides. the sockets are twist lock into the headlight housing, so you just twist righty to tighty and lefty to loosy, remember the orientation of the sockets cuz they only fit one way (there's three prongs but the sockets, they only locks in one orientation). to remove bulbs you must use a small screwdriver to push the locking tab, after that just pull out the bulb housing from the socket.
the high beams are the same but on the passenger side you'll have to remove the radiator overflow tank, this is done easily by removing two bolts i believe they are 10mm. the highbeam bulb sockets are a finger push locking tab so you don't need the screw driver, sorry no pics but this is real easy, just took a little figuring out. woulda been much easier if someone told me like i just did.
Old Jul 25, 2004, 07:15 AM
actually, if you look in the owners manual on page 7-43, it shows you how to do it. That is what I did and it was easy.
Old Jul 25, 2004, 10:59 AM
I have the 55W super whites. I don't like them because they are still to blue. I want the 80W ones. If anyone wants the 55W super white send me a PM with a offer.
Old Jan 28, 2010, 02:50 PM
Nitrotiger's Avatar
so how are the 80 watt holding up in the housing any melting? or wire ?
Quick Reply: Supreme Power Super white H11 Bulbs installed...WOW!
