My GG Evo IX with 18" x 9.5" Rota DPTs & 275/35-18 NT01s
In the rear, the inside tire sidewall is within 1/8" of the lower control arm... I doubt I could fit 285/30-18s without a 5mm spacer and longer studs. Also, all of my fender lips are rolled, and my rear spring rate (600#) is enough to keep the tires from compressing too far into the fenders.
Your ride looks awesome Hsun!!! This is definiately an awesome street and track setup for the Evo 8/9. Be sure to keep us up to date with your results from this season ![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
While most street and lightly tracked cars will run a 255/35/18 or 265/35/18 (fits great on the 18x9.5 wheel) you can definiately go wider if needed. Dedicated track cars can take advantage of this setup and run some massive 275's (We even have one customer who recently put a slightly wider/shorter 285/30/18 tire on his 18x9.5 DPT's
). A 265/35/18 will still perform very well and be more than enough for most street/track cars ![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
-Dan
![EEK!](https://www.evolutionm.net/forums/images/smilies/eek.gif)
-Dan
(a lot of variance because of the different amount of stick-on weight required for balancing).
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
EGbeater
Sep 19, 2016 05:50 PM
EGbeater
38
Apr 25, 2015 10:22 AM
EGbeater
Mar 25, 2011 10:03 AM
EGbeater
Oct 20, 2010 11:39 PM
