honey's 6765 forward facing build thread..
#272
You actually don't want a really large intake manifold if you're going to run less than a 35R (say fp black etc), because it's just going to rob you of both hp and torque. You won't be able to build enough pressure in the intake manifold to warrant its size.
I'm just saying this because we went through many intake manifold test on our formula car and bigger is not always better. If you're going for the flashy factor well then the Magnus would be ok.
thank you
#280
it is a good thing they cut the intake apart,do you guys see all the aluminum burrs in there at the bases of the secondary injector bungs...imagine if that broke off and went through the motor...........
#281
the lip looks good imho,if you guys didnt know it was homemade you would be all over it...
