Critique My Photography
-Jalal
Theirs many options out there for removing noise from grainy pics.. Check out the difference on the windshield & front fender
I did this in 5 mins with a photoshop plug-in called topaz labs (they have free trials on their website)
How come everyone on this forum has some BS to say I said I did it in 5 mins
bringing the Saturation down actually made the detail your talking about kinda fade, not the de-noise^
The de-noised picture is actually sharper see the nice scratch on the bumper ?
You're on the right track. You've set your 7D ISO at 200, you've used manual mode with a slow shutter speed of 1/30 to 1/40, aperture is small to keep most of the car in focus, but your pictures are quite noisy and grainy.
Rolling shots at that speed will naturally induce noise into the picture with the movement, but I think you're post processing in CS4 is also accentuating the noise. I noticed you used spot metering, did you meter off the wrong area and had to push the exposure compensation by a bit in PS? I would say you would've increased the clarity and saturation so that accentuates the noise too. Perhaps you set an additional layer for the car itself and increased the brightness for it pushing the noise too. Posting the picture at high resolution like that and allowing pixel peeping doesn't help the issue of seeing so much grain. A slightly faster shutter speed of 1/50 to even 1/80 would have reduced motion blur and reduced the grain in the picture.
Composition wise the 2nd one does nothing for me, but I like the 3rd and 5th shot...well 5th shot the most. I like the colour saturation - even though it may have increased the noise.
Which lens were you using Canon EF17-40 f4L?
1.) Look at the open vent on the hoods. The top one has detail (mesh). The bottom one is completely smoothed out and look like there is a plastic insert (or not open).
2.) Look at the headlights. Look at all the fine lines that are present in the top version. Then compare it to your version. All the fine lines are gone/smoothed out.
3.) Look at the hood / fender line on the driver side towards the back of the picture. The top one is completely defined all the way from front to back. The bottom picture has un-nature jagged lines in it which usually occurs when you try to sharpen a picture that went through a noise reduction program. This is the same for outer lips of the wheel, mesh in front of the intercooler.
Sharpening was applied after the noise reduction to bring back some of the lost detail. I use Neat Image on some photos and yes it takes literally 10 secs to obtain a noise sample and run the noise reduction program.
It's a great noise reduction software.
http://www.neatimage.com/
