18x10 +25
#31
#33
it turned out with the 25mm spacer..it will hit the back of the fender..i shaved and shaved still rubbing so i installed evodave kit with those wide fenders and hopefully that will take care of the problem
see how flush it sits? with evodave kit pushed it to about 40mm wide now so i really doubt this setup work on stock body at all!
#34
yes...i was hoping it fit without no spacer but the face is flat and so is the backing...it fits the back just fine..not the front... maybe if they had 0 offset in this wheel design it will fit front... i seem plenty of people run 18x10 on stock body but it all depends on the wheel design and offset..this one im running has a good 3+ inch lip
#35
This is EXACTLY the thread i needed,also interested in throwing them on a stock body haha thanks for starting it climb on.The price is just unbeatable for an 18x10 that looks awsome.J8dailo,you say the rears fit fine no spacer needed? and as far as the fronts a 25mm spacer is the minimal spacer you need to clear the front calipers? I was planning on going with a 265 for some more clearance and wouldn't mind having the evodave fender mod with some camber to make it work.
smgevo
108
Mar 13, 2018 08:45 PM
DrivelineSales
Evo 'For Sale' Wheels / Tires
18
Nov 22, 2014 07:11 PM
bnr34rb26dett
Apr 2, 2014 04:42 PM
RavSpec
EvoX 'For Sale' Wheels / Tires
54
Jan 12, 2012 01:33 PM
