NsPyR's EVO !!! China
#212
I will also be getting the Alcon BBK 365mm front 6 pot monoblock calipiers front and 4 pot rear..... Now deciding if i want to get AD08 tyres or A050 tyres.... for the March track event in chendu....
#213
This weekend i finally finished tuning my evo 9... felt it is so powerful already so i asked my mate to bring out he's 2011 porsche turbo s for a friendly race.... Damn that car is so fast.... we both used launch control and it was quite even, but every time i change gears he would leap in front by half a car length or more... by 400m he was around 2-3 car lengths in front of me.... went to check out on the internet and apparently the turbo s can do 0-200km/hr in like 10.8 sec. OMG that is one damn fast stock car.....
#214
Nice car. Horrible engine choice. All BC parts are crap. I would switch over to a 5 speed. The 6 speeds are very weak even if they're built. Shep builds great stuff.
For tires, I'd go with the Advan AD08 like you mentioned. Some others I would also go with are, Toyo R888 or Michelin pilot super sports. All very good street tires.
#215
What's wrong with BC ? can you elaborate more on this ?
#216
Ok my evo build is more or less complete now, below is my build list
BC 2.3 Stroker Kit
BC 272 CAMS
FP Black Turbo
Forge Acuator (red spring)
HKS SQV BOV
K20 Ignition Coils
S90 70mm throttle body
Port and Polished Intake Manifold
RC 1000cc Injectors
AMS Fuel Rail
Sard Fuel Regulator
Buschur Racing Double Pumper Fuel System
Link G4 Plug and Play ecu
HKS Type R Intercooler Kit and pipping
HKS Oil Cooler
Golpher Radiator
HKS Low temp Thermostat for Oil cooler
Ralliart Low Temp thermostat for Radiator
Torque Solutions Engine Mount Kit
ORC twin plate clutch
Shep Trans Ultimate Ratio Gearbox and 4.11 Final Gear
Shep Trans Stage 2 Transfercase and Wavetrac LSD
Tein Monoflex Coilovers and EDFC
Alcon 6pot Monoblock and 4 pot BBK
Whiteline bump steer correction, front roll centre adjust kit & Front steering precision kit
TE37 SL 22offset 9.5J 18inch Rims
Advan AD08 255/35/18 tyres
HKS turbo back exhaust
HKS exhaust manifold
HKS turbo timer
Greddy Profec B boost controller
Defi BF Gauges
Billion exhaust themo wrap
ARP head and studs
ACL engine bearings
Port and Polish head and Balance Chamber
FP intake pipe and K&N Air Filter
Power Timing Belts
Agency Aluminum Shorty Antenna
Seibon CF bonnett
Cusco front and rear sway bars
Alpine CDA-117E CD player
SD audio Amplifier
Kicker 12" subwoofer
Rave Front and Rear Speakers
22/12/2011
BC 2.3 Stroker Kit
BC 272 CAMS
FP Black Turbo
HKS SQV BOV
K20 Ignition Coils
RC 1000cc Injectors
AMS Fuel Rail
Sard Fuel Regulator
HKS Oil Cooler
Golpher Radiator
HKS turbo timer
Defi BF Gauges
ARP head and studs
ACL engine bearings
Power Timing Belts
Seibon CF bonnett
SD audio Amplifier
22/12/2011
#220
Now I'm deciding if I want to upgrade my Orc twin plate clutch to the carbonetics triple plate clutch..... Anyone using the carbonetics clutch??? Also I am think of upgrading my tein monoflex coilovers to something else, or have them change the springs to something more aggressive...
#222
#223
Just ordered my Carbonetics triple plate clutch from maperformance... Can't wait too try this clutch out as I have heard lots of good things about it, and maperformance have been very helpful !!! Just wondering how the Carbonetics conversion from pull to push type clutch install is done compared to the Ams clutch kit...
#224
nspyr - some pics of the push-to-pull conversion for my evo, using carbonetics triple clutch in my build thread if it will help you:
https://www.evolutionm.net/forums/9272546-post3.html
(towards the bottom of that post). zai jian!
#225
