NsPyR's EVO !!! China
Hi everyone, i am new to this forum. I used to have a 220whp 2006 Turbo Charged Civic but due to a big trucks brakes failing, he smashed into 5 cars including mine and basically wrote it off, so i recently bought a second hand Evo 9 which costs me 270000 RMB. When this car came out in china new it cost 430000 RMB. The car was basically stock and after purchasing it, i wanted to change my clutch so i started drifting and doing 360 drift/spins but i then blew my ACD (OUCH that cost me 16800RMB to replace).
Below are pics of my car when i just purchased it, and drove it from Nanjing to Kunming which is 2600kms....
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/DSC00646.jpg)
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/DSC00645.jpg)
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/DSC00609.jpg)
I have now started modifying my car, the mods are as follows;
BC 272 Cams Set
BC Springs and Titanium Retainers
FP Black Turbo
Megan Exhaust manifold
HKS Turbo Back Exhaust
FP Intake Piping and K&N Air Filter
Greddy Profec B Boost Controller
Dixcel Brake Pads Front and Rear
Brembo Front Cross Drilled Rotors
Cusco Front and Rear Sway Bars
ORC Twin Plate Clutch
TE37 SL 18" Rims
HKS SQV Blow off Valve
Rave Front, Rear Speakers with the Rave Amplifier and 10" Subwoofer
Eclipse DVD/CD/Radio Deck
Haltech PS2000
Tien Monoflex Coilovers with EDFC Control Unit
HID Lights for both low and high beams
RC 750cc Injectors
Walbro Fuel Pump
Sard Fuel Pressure Regulator
Stock intercooler
Stock Bottom End
Power Timing Belts
CF bonnett
CF Ralliart Lip kit
Defi BF amber 60mm Oil Temp, Fuel Pressure, Exhaust Temp, Turbo, Water Temp and Defi Display Unit
AEM 52mm Wideband AFR Gauge
I am in the process of getting these parts installed and then tuned and will update you guys with pictures and all in the near future...
Updates 24/10/2010 I am now getting these parts now.... Will update with pics soon...
1) BC 2.3 stroker kit (86mm)
2) BC intake & exhaust valve (+1mm)
3) Cometic gasket 1.4mm
4) Arp head
5) Arp stud
6) Oil pump
7) Water pump
8) Rebuild engine kit
9) Rc 1000cc injectors
10) Main & conrod ACL EVO 9 bearing
11) Custom Port head
12) Balance chamber
13) Remove balance cam
14) Hks oil cooler
15) Port and Polished Intake Manifold
16) S90 70mm throttle body
17) duel walbro fuel pump setup
18) HKS type R intercooler kit
19) Link EMS boost controller
20) AEM water Injection
21) Sheptrans Ultimate Ratio Gear box and 4.11 final gear
22) BC 272
23) ORC twin plate clutch
24) K20A ignition Coil system
25) Link EMS g4 plug and play
26) Polyurathane Motor Mounts
27) Forge Acuator 1.5bar
28) Goodridge Stainless steel braided brake lines
29) Stainless steel Clutch line
30) Alcon monoblock 6 pot front 4 pot rear Big Brake Kit
31) Fuel Rail
32) Shep Transmission transfer case
33) Wavetrac Front LSD
Ok my evo build is more or less complete now, below is my build list (updated 10th May 2012)
Street Setup
BC 2.3 Stroker Kit
BC 272 CAMS
FP Black Turbo
Forge Acuator (red spring)
HKS Oil Cooler (left side)
Setrab Oil Cooler (stock position right side)
K20 Ignition Coils
RC 1000cc Injectors
AMS Fuel Rail
Sard Fuel Regulator
Buschur Racing Double Pumper Fuel System
Link G4 Plug and Play ecu
HKS Type R Intercooler Kit and pipping
Tial Q BOV
Golpher Radiator
HKS Low temp Thermostat for Oil cooler
Ralliart Low Temp thermostat for Radiator
Torque Solutions Engine Mount Kit
Carbonetics Carbon Triple Plate Clutch
Shep Trans Ultimate Ratio Gearbox and 4.11 Final Gear
Shep Trans Stage 2 Transfercase and Wavetrac LSD
Tein Monoflex Coilovers and EDFC
Alcon 6pot Monoblock and 4 pot BBK
Whiteline bump steer correction, front roll centre adjust kit & Front steering precision kit
TE37 SL 22offset 9.5J 18inch Rims
Advan AD08 255/35/18 tyres
HKS turbo back exhaust
Greddy Profec B boost controller
Defi BF Gauges
Billion exhaust themo wrap
ARP head and studs
ACL engine bearings
Port and Polish head and Balance Chamber
FP intake pipe and K&N Air Filter
Power Timing Belts
Agency Aluminum Shorty Antenna
Seibon CF bonnett
Alpine CDA-117E CD player
SD audio Amplifier
Kicker 12" subwoofer
Rave Front and Rear Speakers
Map Performance Turbular Exhaust Header
Wider front CF fenders
Extra Parts for Track Events
Spare set of Rims 57D 18x9.5J 22 offset Flat Black
Left Headlight Air Duct Intake
A050 Tyres 255/40/18 & Hoosier R6 255/35/18
Carbon Fiber Doors & plastic Windows (reduce weight)
Custom 90mm Exhaust for Track Events
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/66e8da6c.jpg)
BC 272 Cams Set
FP Black Turbo
TE37 SL 18" Rims
Haltech PS2000
RC 750cc Injectors
Walbro Fuel Pump
Stock intercooler
Stock Bottom End
Power Timing Belts
CF bonnett
CF Ralliart Lip kit
4) Arp head
5) Arp stud
6) Oil pump
7) Water pump
12) Balance chamber
14) Hks oil cooler
22) BC 272
31) Fuel Rail
Street Setup
BC 2.3 Stroker Kit
BC 272 CAMS
FP Black Turbo
K20 Ignition Coils
RC 1000cc Injectors
AMS Fuel Rail
Sard Fuel Regulator
Tial Q BOV
Golpher Radiator
Defi BF Gauges
ARP head and studs
ACL engine bearings
Power Timing Belts
Seibon CF bonnett
SD audio Amplifier
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/a99e04a3.jpg)
This was my old ride, and u can see i was hit from the rear from a truck that was overloaded and brakes failed.... RIP civic... In china we only have the R18 civic and we don't even get the Si version or Type R version...
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/20100320095.jpg)
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/20100320094.jpg)
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/20100320093.jpg)
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/20100320098.jpg)
Pictures of my old ride...
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/CIMG3503.jpg)
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/CIMG3504.jpg)
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/CIMG3505.jpg)
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/CIMG3507.jpg)
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/CIMG3417.jpg)
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/CIMG3402.jpg)
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/CIMG3403.jpg)
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/CIMG3404.jpg)
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/DSC00074.jpg)
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/2009-10-2114-29-58_0013.jpg)
Some of my new parts getting installed on my evo 9...
My Twin Plate ORC clutch;
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/DSC00858.jpg)
BC 272 CAMS, Springs and titianium Retainers
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/DSC00846.jpg)
A pic of lots of my parts
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/DSC00834.jpg)
Tien MonoFlex Coilovers with EDFC controller
![](http://i213.photobucket.com/albums/cc28/yeoadrianyeo/DSC00864.jpg)
I will update u more soon.....
sorry for the delay of the pics guys.... My car should be complete sometime mid June, and my TE37 SL rims should reach within 2 months time.... will update soon
