Archiebabes 2001 Mirage To EVO V Conversion
#46
the only states you can get away with registering cars like the evo V is states like florida and arizona. both states could care less about the cars that drive on their roads. that's why there's a ton of skylines and other random imports in FL and AZ. even though they are titled and registered, ICE can still swing by and sieze it. but they are only after skylines, it seems.
#47
what if i buy one register it in fl then drive it around in LA and TX lol i could do that haa. but i understand just buying one then stripping it and putting it all on a mirage that way you ensure they can never take your car which is smart but for like the 15k-18k its going to cost me to do this i might as well get another in general which is my WHOLE ISSUE with this. I would not mind having a old school evo V or 6 as a DD but thats alot of work and dedication not to mention alot of up front money i would need form jump street. i would need like 6k+5K so 11k cash to get the evo V and get it imported. then i have to buy a cheap mirage and have the swap done which i could take my time on that part at least but still alot.
You need basically from Mirage only steering and front buckle head.
But Evo has sharper steering so it will not drive the same.
Why use Evo 5/6? USDM Evos without ACD are basically same under the bonnet but have larger weight. So with not that much mods you can keep with them easy. I have VI and it is not a problem to overrun same HP rated IX.
Not mentioning it looks much more hardcore
#49
very interesting indeed, i know its been getting OT, but interesting reading and definately have not seen an imported evo run around 9k..... doesnt make sense to me cause i was looking for a pre VIII before purchasing mine.
as a side note, for a V or VI replica, does anyone know would it be any more difficult to just swap an 8 or 9 engine/drivetrain into a mirage chassis like this? also what is the most basic model of the mirage (assumption that they are cheaper and lighter)? maybe the year span of the model to choose.
@ OP: can we get more pics of the mirage? interior shots also?
#50
To the above post, I can't confirm this, but I heard that to use an Evo 8 transmission, you have to use the Evo 4-6 transmission and transfercase. Everything else should fit though.
#53
#54
#55
#57
I see the pic above you are already covered. If you dont mind me asking mine giving me a price list so car i was thinking about making a evo 6 just for a dd nothing special if its going to end up being cheaper them me making a forutne rx7. i was always curious about such a conversion. body parts next up nice. you going oem spoiler or aftermarket like voltex?? once those parts are recieved and you install them are you repainting the car then or moving to interior???
#59
I am going with an OEM EVO VI Wing and Trunk with garnish.
I might buy a TME front bumper, and swap out the V bumper every other month for a different taste.
Yes, the car will be repainted in Red when all the parts are installed.
Then I will move on to the interior conversion.
#60
I will give you a price list for the parts.
