VOLTEX rear arches?
Thank you!
And if you're a official VOLTEX dealer and had sold / installed many kits like this one you shold know the truth With removing some iron from the rear arches do we SOFTER and WEAKER them? Should any kind of re-inforcement be applied?
Thank you!
Thank you!
This is the same procedure used by CBRD SpeedFactory:
http://i2.photobucket.com/albums/y27...r/DSC_1706.jpg
http://img.photobucket.com/albums/v2...USERANGLE2.jpg
We'll try and post some shots of their install.
IMO, u dont need to cut that high. cuz then u start splitting the structure from then body. that extreme enless ur running crazy wheel tire set up. this is what i did with 275/35's with 18x9.5 wheels.
https://www.evolutionm.net/forums/ev...r9s-build.html
here the link to my page for the voltex set up on my car.
But yes, you are right under the normal over fender, you dont need to cut that high up, your install looks great.
if youre asking me then yes, i had to cut it for the double over fender since the regular over fender isn't wide enough
bolted underneath to the jdm rear, doublesided tape along the edges and through-bolted to the oem rear quarter panel
