My '03 RR VIII
Old Aug 26, 2012, 02:26 PM
okevolutionVIII's Avatar
My '03 RR VIII
Been a member here for 7.5 years, think it's time to post some pics. Car is a little dirty and engine bay is set to get by for now so ignore the mess.
Old Aug 27, 2012, 02:32 PM
100% Self Built and Tuned
Rotating Assembly Balanced
Cylinders Ridge Honed and Crank Micro Polished
Haltech PS1000 ECU (41psi on 91/methanol)
Pioneer AVIC N2 Navigation
GrimmSpeed Master Cylinder Brace
Spoolin' Up Injector Clips
Summit Racing 16 Gallon Fuel Cell
Summit Racing Digital Fuel Gauge
AMS -6an Fuel Return Line
RedHorse AN Hose Fittings
-8AN Fuel Feed & Return Lines
Bosch 044 300lph Inline Fuel Pump
Fuelab 818 Series -8AN Inline Fuel Filter
Custom 10ga Fuel Pump Rewire Kit
FIC 2150cc Fuel Injectors
DevilsOwn DVC-30 Stage II Methanol Injection
Saikou Michi Dual DC3 Oil Catch Cans
STM -6AN Rear Valve Cover Fitting, Full SS Braided Clutch Line, Oil Cooler Delete
Torque Solutions Aluminum Shifter Cradle Bushings, Driveshaft Carrier Bushings, Urethane Exhaust Hangers
Speed Source Brass Shifter Cable Bushings
Xona Rotor 8267 (6467) .85 A/R Turbo
PeakBoost HVS Top Mount Equal Length Manifold, 3" V-Band Downpipe, 2.5" Aluminum LICP
Tial 44mm V-Band Wastegate
Buschur Racing 3.8" Garrett Core Race Intercooler
Nesei Engineering 2.5" UICP
Green Performance 4"x13" Air Filter
Blitz Full Auto Turbo Timer
Glowshift Oil Pressure, Oil Temp, Boost Gauges, Oil Filter Sandwich Adapter
Rexpeed Dash Triple Gauge Pod, CF U.K. Trunk Badge, Carbon Fiber Type-C Wing
OEM Evo IX Tail Lights
Vibrant Ultra Quiet 3" Resonator
Varex 3" Remote Valve Muffler with Cherry Bomb Tip
MAP 3" V-Band Cat-Back Exhaust
English Racing Phenolic Intake Manifold Spacer
GSC R2 Stroker Cams
Kiggly Hydraulic Lash Adjuster
GSC Valve Springs & Titanium Retainers
Power Enterprise Kevlar Timing Belt
Wiseco 85mm 9.0:1 Stroker Pistons
Eagle 150mm H-Beam Connecting Rods
JAM Ultra Spec Piston Rings
Stock 100mm 4G64 Crankshaft
ACL Race Main/Rod/Thrust Bearings
MAP/A1 Technologies 11mm Dog-Point Head Studs
ARP Main Studs & Rod Bolts
Cosworth Crankshaft Oil Scraper
Fluidampr Harmonic Crank Balancer Pulley
Machined Front Balance Shaft
Rear Balance Shaft Deleted
Balance Shaft Delete Crank Pulley Spacer
Braided Stainless -4AN Turbo Oil Feed Line
Earls -4AN Inline Oil Filter
Brad Penn 20w-50 Oil
Motul Gear 300 75w-90 Transaxle Fluid
Redline Heavy Shockproof T-case Fluid
Curt Brown Extreme Ported 70mm OEM Intake Manifold
Boomba 75mm Throttle Body
Custom Honda/Denso COP Ignition
ToxicFab CAS Heat Shield
Mishimoto Evo IV-VI Aluminum Radiator
Mishimoto Evo IV-VI Upper Radiator Hose
OBX Silicone Lower Radiator Hose
Bushwacker Evo IX 5 Speed w/ VIII 3/4 Gears and HKS 4.11 Final Drive
Competition Clutch Twin Disc Clutch & Flywheel
Circuit Hero 3.75" Shifter Extension
AEM UEGO Wideband O2 Meter and Methanol Failsafe Gauge
Omni 4-Bar MAP Sensor
Grimmspeed 3-Port EBCS
Blox Racing Front Engine Roll Stopper, Engine Magnetic Oil Drain Bolt, 2" Antenna
Do-luck Replica Front Lip
Smoked Front Signal Markers
EGR Disabled/Removed
PCV Valve Removed
Old Aug 27, 2012, 02:39 PM
itsmrrizz2you's Avatar
Nice car looks like you got a lot of great parts time n money invested.. Good luck with it
Old Aug 27, 2012, 04:43 PM
donmeca2020's Avatar
not bad at all, looks to me like your missing the the grill and hood vent on your hood. any interior pics ?
Old Aug 27, 2012, 04:48 PM
Yeah, the bottom grill was removed long ago and the hood vent will need to be modified for the dump tube when I re-install it. Interior is very dirty from all the installs I did during the build, the headliner and all 6 pillars are still removed for now but I can get a few pics.
Old Aug 27, 2012, 04:55 PM
nytalonTSi's Avatar
Car looks good man!
Old Aug 27, 2012, 04:56 PM
no no i wasn't talking about the grill in the bumper i mean't the mesh thats near the hood vent.
Old Aug 27, 2012, 07:05 PM
The mesh is still there, if you look at the pic just before the 1st pic of the engine, you can see it has black soot from the dump tube on it.
Old Aug 27, 2012, 07:23 PM
Some interior pics added.
Old Sep 25, 2012, 08:11 AM
macspeed702's Avatar
any luck on the smim i see some bad things intake mani
Old Sep 25, 2012, 08:36 AM
importmachine's Avatar
how is visibility with the gauge pod there on the dash? Does it obstruct your view? I'm thinking of getting one like that.
Old Oct 4, 2012, 09:56 AM
It doesn't obstruct the view too much, I also have gauge visors installed that eliminate the glare on the windshield at night. I'm thinking of experimenting with the Autometer lower console gauge pod to see if I like it any better and it's fairly cheap.
Old Oct 8, 2012, 07:29 PM
evo3429's Avatar
Awesome car, RR is by far my favorite color!
Old Oct 8, 2012, 07:55 PM
Mistaken's Avatar
Very nice!
Old Dec 18, 2012, 09:04 PM
batty200's Avatar
How much power did this make? How responsive is it? Do you like the HAFE kit overall or do you feel it is lacking? I have one with a 35R I will be installing and I love it on paper but never saw any results using it. If I did see results they were so long ago I dont recall.
Thanks a bunch!
Quick Reply: My '03 RR VIII
