Drop-In Hood Vent Cover for those rainy days
A few of my friends like to run their cars with the hood vent removed. I think most prefer it this way actually (especially if you have an aftermarket manifold that's nice to look at), but rain or snow makes everything look nasty pretty fast. So with some help from my friends, I came up with this hood vent cover that drops into place on the factory grill and is secured with wing nuts/washers. I powder coated it wrinkle black to keep it clean. Only thing I think Ill change is adding a couple more studs so that it sits more recessed all the way around when it's tightened. The idea wasn't to run this all the time considering the amount of heat it will be holding in, but for it to look good when it is installed. What do you guys think?
Don't mean to be a hater, but do you drive the car with that on? You mention that your car is running hotter with it on...That's why the Mitsubishi Engineers made that outlet. I leave my original vented aluminium (RALLIART) grill in my trunk, so if it should rain, or snow, it takes me a minute to put it back on and it doesn't change the temp. Otherwise, mine is off 24/7. My engine and aftermarket exhaust manifold still look great, and yes, I was caught in the rain a few times...
I think that 'plug' you made is a great idea if you park your car outside and think it might rain/snow, then I would put it on, otherwise I think you are making things worse. No one wants extra heat in an Evo. Not only is it power-robbing, but just plain bad news for any car. If Evo Rally cars can run in snow and any kind of bad weather with the original aluminium grill on or off, that's good enough for me, lol. Good luck and watch your temp. gauge!
This is one is made from 304 stainless. While aluminum would have been lighter, this one hardly weighs anything and is more rigid at the same thickness. Steel also allows for a lower profile tig weld around the studs, in turn making it easier for the cover to sit as flat as possible against the grill.
I never said the car was running hotter with it on, this car doesn't even have a drive train in it lol. We have all seen the heat radiating out while sitting at a stop light, which is why I would never want to rip on it or purposely run the car hard with this cover on. Ideally its for when the car is parked (especially for snow) or if Im running around and it rains unexpectedly. There are many factory turbocharged inline 4 cylinders with iron blocks and exhaust manifolds that sit close to the radiator that do not have hood vents, so while I think it will run much cooler with the cover off, I hardly doubt it will lead to overheating. I have yet to test it but will soon. The weather will likely never damage your manifold, but I personally cannot stand watermarks that burn into the runners and require constant up keep to keep them looking fresh, not to mention rusty bolts/exhaust housings/center cartridges.
Nj... No reason to hate... Its clever... I've never had a problem with rain and havent had a baffle for 6 years now... Also i couldnt imagine why your car would run hotter with that plate... It doesnt suddenly seal the engine compartment... It certainly wouldnt increase coolant temps... Maybe inlet temps but idk since its already raining in this scenario... Anyway its clever and i like the thought of making custom parts so good job... Not many people think outside the box these days...
I reread and i get the impression this is more to keep from detailing the bay so often... Yes? We were typing at the same time apparently... Nevermind
My question is why drop all the money into your car to stiffen the chassis nj9mr and then add a front sway bar that reduces turn in?
I had been wanting to make one for a while and then I saw Collin from Toxic Fab beat me to it, however his requires removal of the factory grill and it bolts in its place. Looks really good but is more of a long-term install rather than just popping it on. I know his car makes a good bit of power and I don't think its had any overheating issues.
Also, what's surprising about the oem hood grill is that the "honeycomb" spacing is the exact same on every one. I've set this vent on like 6 different hoods and the studs fit perfect every time.
ha yes I didnt see your response until after mine either. Thanks though, I appreciate it. Yes mainly just to keep the bay clean and avoid constant upkeep. I know not everyone cares that much about the appearance under the hood, so it may not appeal to everyone.
To those of you concerned with heating issues, go talk to the daily driven 1000+HP GTR's with no monster hood opening. As well as many other cars that make more power, and go faster then any Evo I know of.
Collin.
Huh?
First off, did you read the very first sentence I wrote? I am NOT hating...I don't want my post to be an issue on the OP's thread. I also didn't know his car was a roller/no drive train. I DO think it's a good idea, and heck, I'd probably buy one if he decides to make them. I won't put it on my car when ever I drive it, but for sitting around, sure! I also respect people who think out of the box!
Lastly, I guess you and I come from different 'schools of thought'. AGAIN, I AM NOT HATING...Just giving my opinion. Yes, I added all those support braces, roll cage and now both sway bars. I didn't mention yet, but I also have coil overs to go on and I am changing every chassis bushing to the polyurethane ones. The car as it stands now, handles amazingly! My fellow club guys that follow me through turns, etc. tell me that they never see my brake lights go on! Lol. "She corners like she's on rails"! With the sway bars put on recently, the suspension is more 'level' to me. I am TOTALLY satisfied with the results! I can't wait to add the above mentioned other parts over Winter. Peace!
Takes about 5mins to install/take mine off. Also, not once have I had a issue with over heating even on my Toxicfab half size rad, and Texas heat. Mine is made of 6061 aluminum, while I believe yours is stainless.. Pretty sure stainless will get a lot hotter and stay hotter much longer then Aluminum, not to mention double the weight savings.
Collin.
Collin.
I had a 2g GSX many years ago. It had an FMIC. Car would overheat. Louvers in the OEM hood solved the problem (this was before we even had Evos in the U.S. w/their decorative hood vents).
Never said the factory vent was "decorative" or not functional. Simply said even a high HP Evo with a half sized rad, 4" thick front mount, has no issues.
sorry it just gets to me...
i do honestly believe the vent is decorative.... i see the smart *** comment and i raise you.... EVERY OTHER 4G63T, EVO 10, sonata's, genesis T, srt-4s, AND the fact the wrc rally car is a lancer... without a hood vent...
i await your smart *** reply...
^^^ i just read collins first comment... so much better then mine... I'm beginning to wonder why pick a fight if you know you are already out gunned?
also OP... after learning collin did a lighter version before you... i have to retract some of my previous accolades... but its still nice..
