How to protect the CF wing from UV?
if I'm not mistaken it is the epoxy you are trying to protect, that is what is harmed by uv rays. the carbonfiber prolly doesn't give a hoot about uv. everyone is right though, keeping it waxed will protect it. if you want to brake the bank get aviation uv protection or boat...
yellowing and haze or dulling is what happens to the epoxy when it is weathered.
So many people said you can't wax carbon fiber, what name brand and specific products from them can be used on carbon fiber?
I f*** up my cf wing using wax on it. It made these wierd swirls under it. It almost looks like a wood design. Better yet, it's yellow also. So the wax didn't help it out either way.
I don't care anyways since I'm getting a cf trunk soon anyways. I would just like to know, so I can keep my new carbon fiber hood protected and not ruin it like my wing. Be careful.
I also have a cf grill that I have waxed a couple times. Nothing bad has happened to it yet. So should it be ok? I won't wax it again, till I find out what's good for it.
Also, what about the Wax as you dry stuff? I usually spray that all over my car when I dry it off. Should I skip over the hood and wing when I use that also?
if your really worried, go and get a layer of clearcoat+UV put on the wing.. I spend 250$CA to do that to my CF hood, and it looks AWESOME. (i even got them to put in some diamond pearl so that it sparkles like mad)
The only thing I noticed in the hood now since after I bought it is that from a certain angle, I can see like this white shade on it in a certain spot. Not sure what it is, but when I clean it, it's still there. I hate cf! It's so hard to maintain! Haha!
I suppose the carbon cloth may fade a bit from the light but it is the epoxy that will show ware and tare. it is the epoxy's quality that shows the cf, if the epoxy becomes dull the cf may look bad but it is the epoxy that has "gone bad". think of it like a clear coat. you want to protect the epoxy and in doing so you will protect the cf.
the factory may have put a clear coat on the tail, as cf hoods should have. either way you would treat it the same.
guys u dont need magical uv products. Just wax ur wing every month or two and u'll be fine. I wax mine like once or twice a month and my wing still looks flawless.
My cf hood looks like it has this gray dull haze over it now after waxing it? Not sure what it is... could it be like oxidation I think what it's called. If I get that new Meguiars 3 step wax, the first one removes old wax, removes oxidatoin and stuff like that. You think the forst step will fix it?
yo pumpdog.. my body shop told me specifically NOT to wax my CF hood. although I spent 300$ beforehand and had special UV and clearcoat put on it. I'm thinking the wax is on your hood and its too thick perhaps? I'd suggest removing the wax thats on it...
same thing happens to me if im at the carwash and i spray wax all over and dont wipe off the windows quickly afterwards.
