My Lotion VII
MagEvoVII
Awesome VII
I PMed you about your aftermarket seat rail. I was wondering if it helps leg room much? Like getting your knees under the steering wheel?
Anyone know if I can get a hold of a set of these in the US comphatible wit the VIII?
Awesome VII
Originally Posted by The Bear
MagEvoVII
Awesome VII
Awesome VII
Originally Posted by purecoda
lotion? don't know if i'd ever call and evo "lotion". sounds about as gay as it gets IMO. looks nice though.
but it does look nice.. 4 some reason i like that spoiler
magevo,
would like to know where did you mount your exhaust temp sensor and also ur oil sensor...... i bought DEFI BF but am not sure where to mount it as i made mistakes with my previous car and those sensors only lasted me 1 day and 12 hours...
Originally Posted by blonde
great looking car bro. the ADVAN RG is cast and that is a fact. doesn't matter though because it is just as strong as a forged VOLK and it is light.
Originally Posted by NoTiGuY
magevo,
The water temp is put on the top radiator hose. Usually this is a samco hose, that's cut out in the middle and an adapter is inserted and clamped down.
On my GTR, they put the oil sensor on this adapter bolt that plugs the oil pan hole. However this may be incorrect because it went out after only one month... not sure on this may be a wiring problem as it went out after a oil change so may be something is loose. So not saying it's the wrong place. It is the easiest install though.
Most commonly, the Oil temp sensor is mounted between the oil filter and the oil pump adapter sandwich. (basically between oil filter and engine) If you have an oil cooler, that is another spot as well.
Sucks because these Defi sensors cost an arm and leg... make sure you get someone that's done it before. Running the wires is real important too so they dont get melted. Some mechanics are good with mechanicals but electronics are like chinese to them (well one that doesn't speak chinese anyways).
good luck.
Originally Posted by twan
more pics more pics more pics more pics more pics
I'll be sure to take some pics at the next EVO club gathering. Oh here's one last one ... mean EVOVII from track day...
