EVO Tweeters
EVO Tweeters
Ok, wanting to get new speakers, and am looking to go with MB quarts component set for up front bc I found the DSE216 for $122. Here is a link to the speakers . My question is, are the tweeters small enough to fit behind the a pillar and are the 6.5s thin enough where they wont hit the winows glass when theyre down?? Thanks
I have infinity kappa 60.5 speakers and they fit ... so if the MBQs are the same depth, they should fit. IMO the stock tweeter setup sucks .. .they don't even use a crossover. I mounted mine elsewhere, because it would have been a major PITA to replace the stockers...
l8r)
l8r)
My opinions on the install and pics can be found here: https://www.evolutionm.net/forums/sh...ad.php?t=84010
l8r)
l8r)
I didn't even bother trying. Like I said ... it looked like a major PITA and I like the fact that all front speaker wiring including the crossover is now on the door itself. Other things I took into considerations:
- I did not want to deal with the headache of running additional wiring into the A-pillar
- might have also had to bastardize the stock wiring harness in each footwell
- crossover would have ended up in the footwell unless I wanted to run extra wiring to and from the door panel and the driver's side footwell doesn't really have that much room to spare.
- it really didn't look like the Infinity tweeters would fit (if they do it's gotta be real close)
Lastly, the stock tweeter grille doesn't exactly look like it will let a lot of sound pass through it, I liked the Infinity grille much better - I also like the location on the door better. High frequencies being much more directional in nature, I felt that the door location would give me better sound. Something that the pics don't really show is that the tweeters I mounted on the door are slightly angled towards the driver as well...
If you run a search on quarts, you might find someone that did install the tweeters into the stock location...
l8r)
l8r)
Originally Posted by EzEddie
so the tweeters wouldn't fit in the stock location?
A popular spot I've seen in most EVO's is just above the door handle closer to the dash. It's a bit more effective there too. The sound waves will not only still meet in the center of your car, but they'll be closer to your ears as well. On top of that, they look pretty good there.
DO IT BABY.
Hmm... the back could go however you want it. Up where evilevo has it is pretty good. Straight to the head. If not, just put em right next to the mid's. Maybe closer to the corners where the rear windshield meets the interior so the treble can bounce off the glass.
Originally Posted by evo81
DON"T,i repeat,DON"T put tweeters in you rear pillar.useless.rear speakers are just fillers.evilevovegas is crazy.
