Installed Tein S Springs...pics
I installed the front tein s springs today....i got too dark for me to finish the rear. i will finish them tomorrow. but anyways, the drop is massive...not sure i like it yet. i took it for a ride, it is a little mushy, but than again i havent installed the rears yet or had it aligned...here are some pics
Isn't the drop going to be more tho since the rear isn't on? The car is more on its nose now because the back still has the higher stock springs. Once you install the rear it should level out.
for safety reasons, i'm sure everyone would recommend a spring compressor... but there really isn't too much pressure on the spring cap. Just lie the whole unit on its side and twist away but make sure that nothing is in the way. One site said it went a couple feet but i'm only moved a few inches.
i got mine fixed three days ago... the springs are rather 'thinner' than the ori's, dont you think so. anyway, the ride was fine on the first day till it settled down a day or two later and its slightly bumpier. Removed a ring from the bump stopper. I've got approx. 1 finger plus gap between tires and wheel arch in front and almost none at the rear and it makes my car looks squatting down... hmm... nevertheless, it certainly looks much nicer..... and now for my rims!!!! still cant find CE28N~!!! Guess i'll have to stick with my 18" TE37....
need some feedback here....
is it much bumpier running on 18" rather than 17"? my friend told me that he scraped the inner plastic cover (inner wheel arch thingie) and had to change it numerous times till he opted back for 17"... and he had mentioned that the ride was so much better....
yeah...i will be hitting the grind right now...i will take some pictures before i finish and after the install...right now it looks like my car is in "heat" haha...with its butt in the air.
thanks for the comments guys...i will take lots of pics
