Vortex Generator Question
Just wondering before I get mine, mitsubishi says it installs with some double sided 3M tape. Just wondering if this is enough to keep it in place at high speeds, also wouldn't this also alow some air to actually get under the generator and could just rip it off from under it? Has anyone installed it this way and had a problem wit it or are people actually molding it to the roof or screwing it down somehow? lemme know how u installed yours and if you'vve had any probs with it
thanxs
thanxs
I don't think anyone here has enough time with theirs to tell you. I know it is not only held on by tape, but it goes under the rubber weather strip drain channel on each end of the roof. That's more than enough to hold it. I'm sure there is plenty of tape along the bottom. It's not going anywhere.
Your emblems are attached with the same double sided 3M tape...they don't fall off. Matter of fact, it takes quite a while to get them off.
I would belive the vortex generator would be equally as challenging to remove once installed.
Yeah its held on by the tape and weather stripping, we've got it on our shop car; Have not had any problems with it at all. Just make sure you clean the area first.
That 3M tape is very strong stuff. On my old RMR lip, that's pretty much all that held it on and never had a problem with it. It is a complete seal, so no air is going under the V.G.
WOW, that seems like an awful expensive part for the performance gains I have seen in other posts. I hope everyone buying one is getting them just for looks. Me personally I'd rather have a cat delete pipe for that price.
But that's just my oppinion, which my wife always tels me means nothing.
A lot of money for a piece of plastic. I agree.
The Evo has so much going on already, the vortex just adds to that. It may attract even more attention since people won't know what it is. They may think it's a bunch of antennas or some rice part from Pep Boys.
The Pep Boys comment sums it all up.
[QUOTE=ctevo]Just wondering before I get mine, mitsubishi says it installs with some double sided 3M tape. Just wondering if this is enough to keep it in place at high speeds,
- i have had it up to 100 and it still stays on
- i would assume airflow gets underneath it , cause water and soap does when i wash my car. but its doesnt rip it off at high speeds (not enough air flow)
- i am just using the supplied double sided tape. but if you are worried you could always use more tape!
thanxs
thanxs
