Enkei NT03+M 18x9.5 +27 +12 +2 offset fitment - pics
Hey guys...
with the new Touge Factory Limited Edition Enkei NT03+M's out...
My PM box is getting flooded with fitment questions.
Here are some pics to show you how they fit...
Tires: Dunlop Z1 Star Specs: 255/35/18
*These tires run wider then most street tires*
Fenders
Front: Stock - untouched
Rear: Rolled / pulled about 3mm
Camber
Front: -2.75
Rear: -2.5
First Pic:
Rear fitment: 18x9.5 +27
*You can run up to 265/35/18's with no problem!*
Second Pic:
Rear fitment: 18x9.5 +12 (15mm spacer)
*Will rub*
Third Pic:
Front fitment: 18x9.5 +12 (15mm spacer)
*No rubbing*
Please note amount of clearance between the caliper and wheel. 10mm spacer will allow the wheel to clear the calipers.
Last pic:
For $hits and giggles... 18x9.5 +2 (25mm spacer)
Hope this helps!
Fenders
Camber
Front: -2.75
Rear: -2.5
First Pic:
Second Pic:
*Will rub*
Third Pic:
*No rubbing*
Last pic:
Hope this helps!
What size spacer are you running? I am running a 15mm spacer with my +27, Im changing to a 10mm. I think you should add that the +27 will rub & also will rub on sideskirt at full lock with a 35 profile tire. Love mine either way.
Let me know if you guys have 10mm spacers. Maybe I can send you my 15mm H&R spacers with studs and get a price cut on the 10mm spacers.
How much for set of that rims? do you have rims and tires combo? if so how much ship it to 98204? I want black to about pretty much the same thing as the picture and info above. PM me if you get a chance.
We don't sell tires...sorry
Is this Mike from Touge factory? We talked on the phone for a while, I am the Evo guy in Iowa. Do you sell 3 to 5mm spacers. I need a set for the rears? Also need a 15 or 20mm setup for the front - the sl[ip-on kind. I already have ARP chariot-studs...
