Enkei RPF1 17x9.5 on Evo (confirm this plz)
Wheels come in tomorow and will be mounted
I will post tons of pics guys
Pic of wheels ordered
(these are 18s but u get the picture)
Alright guys well after a couple months of saving money. It finally came down to ordering my wheels
I ordered Enkei RPF1 17x9.5 plus 18 offset in SBC
I start off by saying these are my dream wheels and I finally ordered them
Can someone plz confirm if I will need spacers up front pr fender mods???
I will be running these wheels with Bridgestone REo1r tires in 245/40/17.
I was planning on getting my alighnment done asap and run sone negative camber.
Btw I'm on stock struts with tein s tech springs. ( So my car sits low and I need to clear)
Plz confirm if I will need spacers (if so what size) and do I need to roll my fenders.
Also I will post pics when they are installed tuesday.
They are going on a 2005 TB evo 8
I'm sure it'll work, but I'm wondering how 'little' is little for the fender work especially on stock bodykit?? haha
But as the guy above said, photos!! Would like to see how far it'll stick out lolz
you might need 5mm front spacers. I have 17x9 35mm and added 20mm spacers which gave me like 1.5mm clearance from the Brembos! My rears are fine w/ 1.5" drop but the inner front wells rub when turning sharp. I have 255/40/17 tires, 245 should be good.
you will have major rear fender rub w/ that low offset. you'll need fender rolls big time in rear. your setup will have wide track stance but need some work on all corners...gl
After searching a bit i found someone with Enkei Rpf1's in 17x10 +18 offset on 255/40/17 tires. He is using 13mm spacers upfront and 3mm rear. But his wheels dont stick out at all
My question on y he is using such a big spacer up front. With this low offset he should need that much)
IM glad to c the fitment is gonna be good
the 17x9.5 +18 will fit the front perfectly. The rears will be another story. Trust me, me and a friend have run this exact setup, both lowered Works springs as well as Swifts. Only problem is the slight rubbing of the inner fender liner at full lock. Ppl running the +38 with 20mm spacer is the same as running +18.
I would say no.
I have the 17x10 +18 offset on my car and fits perfect with NO SPACERS
ya the only reason to run the 38 offset is for better fitment rear. The 18 offset fits perfect on the front. You could do the 38 offset for all 4 and run the 20mm spacer up front so you can still rotate your wheels and tires so not to worry about dismounting them since you would have different offsets.
