Cusco sway bar bushings?
I recently purchased a Cusco 25mm front sway bar from a member here. The bar is brand new, but it doesn't have new bushings. Im not 100% sure if the bar is supposed to come with new bushings or not. If the stock ones are reused, great. If they are not reused, anyone have any idea where I could get just the bushings?
If I dont need the bushings I wont buy them. I just want to know if the stock bushings are reused or if the bar was supposed to come with new ones. I dont want to be in the middle of the install and find out I cant finish it.
Come on guys, I know someone on here has purchased the cusco front sway bar and can answer this for me. I just need to know if the bar was supposed to come with new bushings.
You have got to be kidding me!! 3 days and not one person can answer this simple question for me. Please help me out. If you've ever installed a cusco front sway bar, I just need to know if it came with bushings or not.
You dont need bushings. Only time you need to reaplce them is when they are worn down or you simply want stiffer ones. The choice is yours to make. Either way your car is fine.
Thank You! I thought I would never get an answer to this. I just wasn't sure if the bar was supposed to come with them since I had a cusco rear bar on another car of mine and it came with new bushings.
Originally Posted by Z1 Performance
the front uses the OEM bushing, the rear 18mm version uses OEM bushing, the 23mm rear includes bushings
What is the recommended setting for front and rear bars e.g 116% front , 155% rear.
Nast_Nas
Outlander Sport
19
Sep 24, 2019 03:34 PM
wjamyers
11
Sep 17, 2015 11:05 PM
FS[Northeast]: Complete New Whiteline Suspension Setup
OverBoostedEvo
Apr 9, 2015 01:14 PM
mcgarvey
Dec 1, 2007 12:55 PM
