Toyo Proxes 4
Toyo Proxes 4 and alignment question
I just bought a set of Toyo Proxes 4 tires from Frisby. (Thanks!) I went from the stock Advans to these as my "winter" tire since I live in north alabama. My first impression are that they are very quiet and of course not as sharp as the stockers.
However, I'm a bit bummed at the moment because of the alignment. I had never bothered to have the alignment checked since I picked the car up and the shop was unable to get the right front wheel into spec. I don't know why it is off, but here are the final specs:
By the way the spec they gave me for the evo is:
Is this right? It doesn't match what I've read here in other threads. I was very careful to specify "lancer evolution" and even the work order has it printed on it.
Code:
Front......... Left / Right Camber...... -0.56* / -0.19* Cross Camber -0.37* Caster...... 3.60* / 3.40* Cross Caster ???? (Sorry, can't read this on the printout) Toe......... 0.00* / ???? (ditto) Total Toe... -0.01* Rear.......... Left / Right Camber...... -1.12* / -1.30* Cross Camber 0.20* Toe......... 0.05* / 0.09* Total Toe... 0.14* Thrust Angle -0.02*
Code:
Camber...... -1.0* +/- 0.5* Cross camber 0.5* Caster...... 3.92* */- 0.5* Cross caster 0.5* Total Toe... Front 0.0* +/- 0.16* Total Toe... Rear 0.24* +/- 0.16* Thrust angle +/- 0.15*
Bump. I could really use some advice here. I took the front wheels off and checked that the strut bolt was set properly. Both were pointed inside toward the car. I also crawled around and looked for any evidence of damage but couldn't find any. I thought the sway bar endlink looked a bit off on the right side, but that is probably a result of the alignment not the cause. I can't tell if the control arm is bent, it looks okay to me. Pictures are below if it helps any.l
What else should I look for? I'd really, really prefer not to have to take it to the dealer since that would entail putting the stock exhaust, etc. back on the car. Besides, I don't trust those s.o.b.'s anyway.
navidf
Jul 17, 2009 06:37 AM
Blacksheepdj
Lancer Troubleshooting
114
Dec 7, 2008 09:14 PM
AhmadHasib
14
Apr 12, 2007 07:19 PM
