Recomended Tire Pressure for 18 inch Tires?
I have Kumo 18-235-40 tires. I have NO IDEA what the reccomended tire pressure should be, I would immagien higher then stock, any ideas?
Thanks for any and all info.
Yup stock pressures are best. Even though the tire seems larger, it still holds the same amount of air as the stock 17" tire. The 18" is a bit wider, but also a bit shorter in profile. So the amount of air in the tire doesn't change, just the shape of the air in the tire. Run stock pressures, don't exceed the max psi on the tires sidewall. And yes, I do this as a career as well
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
Inprogress
11
Mar 4, 2008 12:15 PM
Srt-4 Turbo 7
Jul 30, 2007 06:26 AM
N1te
Feb 28, 2005 11:52 PM
