Need help! CAMBER PLATES??
#31
Originally Posted by Bogie
I almost bought those, I still might, unless there isn't a simple fix in order to get the Ground Control to fit.
Dave
#33
Originally Posted by Silencer
I have a set of new (not installed) Works camber plates. Interested in a trade for your Ground Control? I'll need you to measure the id of the bearing and the total length in mm.
Dave
Dave
#35
Originally Posted by instigator
Just an FYI. I put on the Tein Camber plates on my stock strut car and they fit well and was able to get -3.5 from them. Good product for the $160.
Where did you get these at? So do you simply adjust them and give them more camber on race day?
Do the Advans respond well to more camber, or is it mostly for race tyres?
#36
Oh and I got them from http://www.wiredspeed.com/index.asp. They shipped them 2nd day the day I ordered them.
I am running Toyo RA-1s, so I can't speak for the Advans. I can't imagine any tire not liking more contact patch in a turn though.
#38
I was hoping adjusting them for track days would only affect camber. Oh well, doesn't seem like they will work for me.
Dave
#39
/\ I guess i should of been more clear. I only auto x right now....was thinking of getting aligned with camber plates with about -1.5 front camber and when I auto x (about 6-8 a yr.) i max out my camber adjustment with the plates......
I figured with -2.5 to -3.5 front camber it would destroy my tires...if i had it aligned that way for every day driving.
#41
Originally Posted by jfh
Evos come stock with eccentric bolts to increase the range of camber adjustment to a max of about -1.7 to -1.8 degrees. It does not come stock with camber plates which can give you significantly more range than that depending on the rest of your suspension components.
The most you can get is about -1.6
I have the works plates, and they are fantastic. I'm running -2.5, but only drive the car occasionally on the street, as it is primarily a track car.
Percy
#42
Dave
#43
#45
Originally Posted by chrisw
I only know of one person with GC plates and Ohlins... The nut used to bolt the plate to the strut had to be modified to fit. My guess is that its due to the thrust bearing. Worth the effort if you ask me.
