Need help! CAMBER PLATES??
I have TEIN S-Tech Lowering springs and it looks like i need a Camber kit bad.. I recently just got some 19" PRIVAT Fahrens and they fit AWESOME.. but I dont want the tires to wear as much like my stock did withouth camber kit.. I found two so far:
WORKS
or
CUSCO
What is your opinions???
WORKS
or
CUSCO
Originally Posted by [Cyanide]
I thought the Evo comes with camber plates stock?
I have Tein-S Techs on stock wheels, and my alignment is great! I go to JUST TIRES, and the guy that aligns my car is a rally enthusiest, and always aligns it dead on with stock adjusters.
Try to find someone who is qualified...it CAN be done.
Originally Posted by jfh
Evos come stock with eccentric bolts to increase the range of camber adjustment to a max of about -1.7 to -1.8 degrees. It does not come stock with camber plates which can give you significantly more range than that depending on the rest of your suspension components.
Originally Posted by qbbraveheart
so if I were to lower it on springs, I could have the camber adjusted back to stock settings without a camber kit?
Originally Posted by erioshi
It would depend on how far off the springs put things. The eccentric bolts (in the front) are designed to only provide a full 1 dgree camber change. They are all in or all out. The Evo's rear suspension has adjustable eccentric bolts that provide graduated camber changes and they can be adjusted in fine increments.
thanks
Originally Posted by Silencer
Works just came out with adjustable front camber plates for the factory struts if your interested.
Originally Posted by joEvo8
I was looking into it.. til someone mention the Ground COntrol has one too..
FYI I found these on e-bay for $160.
ebay link
You got to love that loosely translated japanese, but it seems they are supposed to work with a stock style spring.
