Brembo STi and Evo stock calipers
I know they use the same pad except a 1mm thicker pad fits on the Evo, so if you're in a tight spot a STI pad will do. As far as mounting a caliper, I have no idea.
STi uses a slightly larger rotor so I would hazard a guess and say that it is 2mm thicker then the Evo rotor which would explain the 1mm pad thickness deal... Again this is a guess and assumes that mayhem is correct.
Originally Posted by NOLIMITMOTORS
hawk lists the same part number for evo and sti pads
Treyzian
35
Mar 31, 2016 11:36 PM
357
Apr 22, 2015 05:07 PM
curtis IX
Jan 28, 2015 06:42 AM
Dowve
Mar 12, 2014 07:40 PM
sti_boy
Mar 1, 2008 08:36 PM
