Definitive weight of 17x9 FN01R-C
Old Mar 9, 2005, 05:02 PM
tsi90awd's Avatar
I bought a set of flat black 5zigen FN01R-C, 17x9 35 mm offset rims from Z1 and weighed one on my ISO-certified lab scale (I'm a university professor). It weighed 19.68 pounds. This is bare - without a valve, center-cap or balancing weights on it. I have to admit, I'm a bit dissapointed. I thought they were lighter. When I get a chance, I'll weigh all four of them and see how much they vary.
Old Mar 9, 2005, 09:01 PM
evo81's Avatar
i thought they were around 18.8.it's not that light of a rim anywayz.if you were looking for that,you should of got some advans or volks
Old Mar 11, 2005, 05:20 AM
instigator's Avatar
Can you weigh the stock rims as well? When I weighed my 5Zigen and my stockers, the 5zigen were lighter (although my scale was not quite as accurate as yours).
Old Mar 11, 2005, 05:39 AM
tsi90awd's Avatar
I'm using the 5zigen rims with a new set of Toyo RA-1 255/40-17 tires. I don't plan to dismount the tires from the stock rims anytime soon, but if I do I'll weigh them and post the weights here.
Old Mar 11, 2005, 08:42 AM
little's Avatar
Not exactly what you where looking for but I weighed mine yesterday.
The stock Enkies with stock Advans, balance weights, stem center cap weigh 44.9lbs
Afterall, its the whole package that matters.
Old Mar 13, 2005, 02:53 AM
trinydex's Avatar
i'd also like the certified sclae reading on the stockers, the 5zigens have been mythed to be very light, they are for their size... they're 1 inch thicker at the rim than the stockers and they do weight approximately less than the stockers still. so... with that aside i don't think anyone should be TOO dissapointed especcially for the price paid.
Old Mar 13, 2005, 03:03 AM
justchil's Avatar
If you would have got the Forged instead of Cast it would have been around 14-15lbs.. but you would have paid 2-4x more a rim
It's still lighter than stock and a good looking rim
Old Mar 14, 2005, 12:41 PM
ryan t's Avatar
1 in thicker at the rim? if thats so then the moment of inertia would be higher with the weight outboard and thus take more to spin even if the wheel is lighter
Old Mar 14, 2005, 03:09 PM
trinydex's Avatar
that is tru but that is the price you pay for wider rubber... you don't see anyone on bicycle wheels just to save rotating mass. inertia can be overcome with power... nothing can replace grip. plus it also gives you more inertia at higher speeds so you can get better freeway gas mileage... i know dumb benefit.
Old Mar 14, 2005, 03:15 PM
EVOTEXAS's Avatar
they are not one inch thicker they are one inch wider. there is a big difference. besides, you could just get the 17x8s or 8.5s.
Old Mar 14, 2005, 05:32 PM
dr.mr's Avatar
I don't think you can put 255/40-17 tires on a 17 x 8 rim, can you?
And I don't think they make a 8.5 wide rim.
Old Mar 14, 2005, 05:41 PM
wojo's Avatar
FWIW, when I got the Enkei RP02-J in 17x9, 35mm offset and put them on a Fedex scale (with centercaps) the weighed 18.6 lbs whereas according to Enkei the should weigh 17.7lbs.
Old Mar 14, 2005, 06:12 PM
trinydex's Avatar
you can... but you get a big "bead" which makes your sidewall useless.
they make a 9.5 so i don't see why they wouldn't have a half size for 8 also.
Old May 6, 2005, 07:15 AM
TURBODAWG's Avatar
I just got mine from FedEx today. FNO1RC in bronze 17 x 9 +35 offset. Pulled it straight out of the box and walked to the super accurate scale I have. Weighs in at 19.2 lbs. This is the bare wheel alone. Not too shabby for a wheel that is 9" wide. Cant wait to get them mounted.
BTW, thanks to Aspec for the killer deal. I also got the Muteki closed end lug nuts, that weigh in at 36 grams a picee (weight from the box). That is 1.2 oz. Aspec includes the lug nuts for $20 with a wheel purchase.
Dont know what the stock lug nuts weigh. I will find out when I get these mounted.
Brian
Old May 8, 2005, 10:52 PM
XxBLACKMAMBAxX's Avatar
I dont get it doesnt 5zigen say these wheels weigh 17.5 lbs? i was looking into these but if they are as heavy as stock I may hold off for something else.
Quick Reply: Definitive weight of 17x9 FN01R-C
