Rota Torque 17x8 hub size - need hub rings?
I heard the Rota Torques 17x8 5x114.3 fit on the Evo. I was wondering though, since the Evo hub bore is 67.1mm, and the Torques come in 73mm, do I need hub rings for it to fit?
If you visit the Mach V Motorsports site they are selling the Hub-Centric Adapters with the Rota Torques. However I called Subydude and they did't know if they were required. Any one else want to chime-in?
Since the Evo hub bore is 67.1mm, and the Torque wheel hub is 73mm, you should have a ring in there. You can install the wheels without rings, but then they'll only be lug-centric, not hubcentric.
--Dan
Mach V
MachEVO.com
--Dan
Mach V
MachEVO.com
My torques from subydude came with rings...they didn't fit, so tossed them in the garbage. the shop that put my rims on put these super thin rings on. today was the first time i rotated my tires. the wheels would not come off. it was a struggle with a bar to pry my rims off without scratching my rims...so i don't really think you need them.
I just put torques on my car the other day and subydude sent me no rings.....they wheels went on perfect and they centered with the lugs great.....I forsee no problems not running the rings....just my .02
WangMan
Apr 10, 2010 10:23 AM
theshadow
Oct 26, 2008 10:13 AM
jamesfr
Aug 22, 2008 07:30 AM
1killertsi
May 14, 2006 07:37 PM
