Will camber plates OR"aftermarket eccentric bolts" fix chronicly UNEVEN front camber?
Originally Posted by erioshi
The eccentric bolts (in the front) are designed to only provide a full 1 dgree camber change. They are all in or all out. The Evo's rear suspension has adjustable eccentric bolts that provide graduated camber changes and they can be adjusted in fine increments.
Current settings of front:
Left: -2.3
Right: -2.0
The tech says that's 'close enough' and that such a slight difference should not cause my car to pull to the right. Is he correct? He also claims that since the front camber may only either be set on -1 or -2, "finer" adjustments are not possible without getting an aftermarket "adjustable" camber something or other. Is he talking about a camber plate, or something else? Above, Erioshi wrote that the rear has "adjustable eccentric bolts that provide graduated changes and they can be adjusted in fine increments"...is fixing my 'right pull' just as simple as installing some of those bolts on the front, which would then allow the tech to even out the alignment? Is that what the tech is taking about?
The tech in question works at Firestone. I purchased a lifteime alignment and since then brought it in 3 times, and still my evo pulls to the right (and yes--I've checked my tire pressure). I'm SO frustrated!
(Also, will the pull to the right cause any longterm damage after driving it it thousands of miles on the highway?)
Any help is very, very appreciated. A search of the board yielded no information which is directly on point to my issue. Thank you!!!!!!!!!!!!!!!
That small difference in camber will not cause your call to pull one side. Tell Firestone to adjust the toe to get the car pulling straight. If they know what they are doing, or not lazy, they can do it.
As others have said, a slight difference in camber should NOT cause your car to track left or right. Bent suspension components can do it. So can toe if it's wildly off.
However, it sounds to me like the problem might be uneven tire wear. That's generally the problem when someone has an alignment that checks out OK but the car pulls to one side. Examine your tires for signs of uneven/excessive wear. Try rotating your tires and see if that helps.
Emre
Emre
Oh, so it might be my toe rather than my camber? Here's my specs--> Is my toe 'off' enough to make it pull?:
FrontL FrontR RearL RearR
Camber -2.3 -2.0 -0.9 -1.0
Caster 3.7 3.9
Toe -0.01 -0.01 0.10 0.13
Does anyone see anything about these specs that would be making the car pull right?
Thanks again.
Caster 3.7 3.9
Thanks again.
Could it be the tires even though I've only got 4,000 miles on them? (they're aftermarket all-seasons)? If so, The rememdy would be to rotate them?
When I said to adjust the toe, I meant they might not have aligned the car while the steering wheel was straight while on their rack. The toe may be right (on paper/spec), but the steering wheel is off. Any alignment shop *should* be able to adjust the alignment to your specs and make the car track straight. If you are sure they did that, then it could either be uneven tire wear or some bent suspension component as other have suggested.
lsx427
Jun 3, 2015 03:35 PM
iodine23
42
Aug 17, 2013 08:57 PM
JDMevoBOOST
Sep 8, 2011 03:01 PM
