What are the Widest Tires Possable?
Originally Posted by soloevo8
What is the widest tread width ???/40/17 able to fit on an evo without hitting the strut tower? Also I am putting them on FNO1R-C 17 x 9.
Thank You
Matt
Thank You
Matt
Robi rolled my fenders; with that, he says I can run 275/40/17's.
I am going to use them purlly for AutoCross and I dont want any rubbing.
Now I am thinkging of going with these choices.
Hoosier 245/40/17 A2S05
Hokohama 245/40/17 A032R
Perrelli 245/40/17 PZero Corsa
Kumho 245/45/17 VictoRacer V700
-245/45/17 Ecsta V710
-245/40/17 Ecsta V700
Does anyone know wich is best for cool to hot wether? I am in Central New York so temp fluctuates by the minute not day.
Thanks for any help
Matt
Thanks for any help
Matt
I have 245 on right now and I am only a pointer finger width away from the strut tower. I was thinking 255 but I am scared. Did you do some kind of mod on your struts to make it so you could fit wider tires on?
I've heard of 280 (https://www.evolutionm.net/features/...vomfeatures/44)
and 275 (www.robispec.com). The right offset and/or spacers is key.
Slowride would this be my best choice for now? Yokohama 245/40/17 A032R Soft Compound
Voidhawk yes but I am looking for something that will work without modifications.
Also, I forgot to mention I will be putting some negative camber on the front and rear. What is the consensus view on how many degrees to go with?
If you haven't been through this thread yet, it covers stock class autocross setup, including tires:
https://www.evolutionm.net/forums/sh...ad.php?t=57489
Since you're running 17x9, it's obvious you don't plan running in A Stock, but I think most of the people running ESP or SM are on 18's, so the stock class thread might be a better source of data. Of course, if you are running ESP or SM, you probably have lowered the car one way or another, so your clearances will be different...
JW
ex-CNY guy...
JW
ex-CNY guy...
