Cusco camber plate install
Hey...I got a set of cusco camber plates for my car and the instructions are all in japaneese. Does any one know of any instructions that are in english? Are there any install guides out there on the net that someone else has documented? And i am correct that these plates will work with my stock struts?
Thanks,
EvoMike
Thanks,
EvoMike
dont know if they work with stock struts as im new to the evo. they should considering they only replace the strut top.
you gonig to need spring compressors and whever tools you need to remove the strut from the car. then you break down the strtut as if you were going to change spring. rebuild everything using the cusco strut top. then zero out the camber plate and get an alignment.
Aby@MIL.SPEC
15
Apr 10, 2018 05:12 PM
nick735
11
Apr 15, 2007 12:58 PM
timzcat
11
May 9, 2004 11:38 AM
b13, camber, cusco, evo, evolution, install, installation, installing, instructions, negative, plate, plates, stock, strut, usco
