Track Rotors - Not drilled or slotted, Anyone make 'em?
Registered User
Does anyone make a one-piece plain rotor that is track worthy, or at least more track worthy than stock? I've only had luck finding slotted, dimpled & cross drilled.
You and me both buddy. I've been *****ing about this since I bought the car.
PM primo8998 He is a vendor and can get you rotora blanks. It's a much better solution than going the expensive stoptech or whatever other huge brake upgrade route.
you can get centric blanks from some vendors. I believe they are the same rotors that Rotor Pros and Rotoa use to make their slotted and drilled rotors.
Centric Blanks
Centric Blanks
I got them recently - centric rotors - the do not crack as quick as some other rotors......
I would have to check how much I paid - I have the receipt at home - somewhere.
They were the least expensive of them all though.
Registered User
Centric Blanks
Centric Blanks
Registered User
Originally Posted by Antemortem
What issues have you had with the stock rotors on the track?
Later in the day, once I did have a nice layer of pad material on the disk, still had brake judder. I don't stop the car with the brakes in the paddock, I drive slowly in first gear and turn off the ignition to let engine compression stop the car. So I don't think I got uneven pad transfer.
My front disks are pretty scored up, so it's probably just time to replace them.
Originally Posted by nubby
First session of the first day I had brake judder when braking down from about 90 mph. I wasn't super hard on the brakes, we were under yellow, it was raining, so I didn't heat them up enough to get pad transfer. That rules out uneven pad transfer being the culprit.
Registered User
Ferodo DS2500. I put them on in March for my first DE day. Bedded them in per the StopTech instructions on the street, then had a DE in May.
The nice blue layer of pad transfer wore off a long time ago, so I started this DE with shiny silver disks. Didn't bed them in on the street, since I planned to just do that on the track. The first three sessions were in the rain with it about 60 degrees outside with a slippery track, so I never got enough heat into the braking system to get pad material to transfer to the disk. The brake judder was there on the first session the first time I got on the brakes.
I used the OEM pads on the rotors, but I've had almost 6 months with the DS2500's.
Registered User
Originally Posted by speedomodel
Where are you racing it, nubby? BTW my brakes haven't been squealing since the car has been in storage.
Did your car have much brake squeal when you put the Brembo front pads back on?
