Nitrogen Tire Fill?
Old Sep 7, 2005, 02:53 PM
  #31
Drifter K's Avatar
It would be pretty cool to see tires bursting into flames. If only it could be ignited.
Old Sep 7, 2005, 03:20 PM
  #32
05 Silver RA's Avatar
actually, i think it might be pretty hot!
lol
Old Sep 8, 2005, 04:53 AM
  #33
djh
djh's Avatar
Originally Posted by kmcconn9
The biggest reason to use compressed nitrogen *in a racing tire* is that it's dry, compared to typical compressed air.
Right answer.
When a tire heats up, the air and any moisture inside it heats up as well. When the moisture inside the tire heats up, the water molecules move further apart, increasing the tire pressure. By removing this moisture, the pressure stays more consistent over the entire heat cycle of the tire.
Sort-of wrong reason. All gases expand when you heat them and the pressure increase is linear with respect to absolute temperature. The problem with water is that it condenses. Then when it gets hot it evaporates and the pressure change is much greater and non-linear.
Dave
Old Sep 8, 2005, 04:59 AM
  #34
kmcconn9's Avatar
seems to be just like what I said but using different terms...either way we are both right..
not worth it for a street car..
Old Sep 8, 2005, 05:05 AM
  #35
djh
djh's Avatar
Originally Posted by wingless
Air = 78% nitrogen, 18% 0xygen, the rest is co2 (IIRC)
You're OK on N2 but O2 is closer to 21%. Suprisingly Argon (Ar) is the next biggest component, at about 1% (it comes from the decay of radioactive potassium). CO2 is present at very low levels, typically less than 0.05%. On a hot, humid day water can make up several per cent, with everything else reduced proportionately. You can see the effect of humidity changes in OBD-II short-term fuel trims.
Dave
Alpha X
14
Apr 8, 2012 05:00 PM
UBR 32
North Texas Evo Club (NTEC)
15
Aug 28, 2010 09:05 AM
jrsimon27
Apr 19, 2009 09:50 PM
juanmedina
35
Oct 31, 2008 09:01 AM
blacklancerr
17
Mar 28, 2005 03:04 PM
Quick Reply: Nitrogen Tire Fill?
