Lowered now car performs different!!
Old Sep 16, 2005, 09:13 AM
Evo_Jay's Avatar
I've heard great thing bout Works spring and they were developed for use with the stock shocks and I have heard great reviews.
Old Sep 16, 2005, 10:29 AM
Almighty Wez's Avatar
If you know how shocks and springs work you would know that is not possible.
By better, I ment not as rough. And it doesn't nosedive as much either
Old Sep 16, 2005, 10:35 AM
KazzEvo8's Avatar
Um, all these responses and noone states the obvious?
I believe that kit lowers front and rear different amounts. Essentially, you've changed the center of gravity a bit. Moreover you've changed the way weight shifts dynamically as the car accelerates, decelerates, and turns.
If handling AND lowering is your thing, get an even drop instead of one that "looks good" (the clearance over the rear tire is higher than that of the front - BY DESIGN - so keep it that way)...
Oh, I recommend Eibach's Pro kit - works for me and my autocrossing '03 Evo ...
Old Sep 16, 2005, 01:58 PM
googoots's Avatar
Well its off to the shop to put the stockers back on then. Im thinking hotchkis if research on the works doesnt turn out that great. Im almost considering staying at stock height. Do you guys recomend sway bars or rear tower braces or ploy bushings as well.
Old Sep 16, 2005, 07:23 PM
SoR
SoR's Avatar
No, I wouldn't recommend putting in an aftermarket rear sway bar, at least not for the stock suspension. With the stiffer rear bar your car will be more prone to oversteer which means you'll get less grip in the rear. It might be ok for tight auto-x courses but for most road racing you'll most likely have less speed in the corners.
Few weeks ago my buddy's Evo was all over the road at Pocono Raceway with the Hotchkis rear sway on middle hole, he was literally going sideways through the turns (and was blocking me to pass ).
Old Sep 16, 2005, 10:02 PM
googoots's Avatar
What are you considering not stock.......full blown coilovers?
Old Sep 17, 2005, 08:08 PM
SoR
SoR's Avatar
Everything that doesn't come from the factory.
Old Sep 18, 2005, 09:20 PM
KazzEvo8's Avatar
Eibach kit and Progress adjustable rear sway - look at RRE...
s7in
43
Mar 23, 2009 09:49 PM
evolucion
14
May 20, 2008 11:46 AM
Slekd
Jan 14, 2008 01:17 PM
alfwoo7
Aug 5, 2007 08:14 PM
evoWALO
Mar 31, 2005 03:35 PM
Quick Reply: Lowered now car performs different!!
