I need to know if Work CR 17x9 +28mm will fit?
With a +28mm offset on a 17x9 wheel, you may have to roll the rear fenders w/ 255 tires. I barely, I mean barely, clear my rear fenders w/ 255/40-17 tires on 17x9 +35mm tires. A 28mm offset will make the wheels stick out 7mm more. I am lowered on coilovers though w/ a one finger gap between my wheel and fender.
It will depend on the tire that you run. With a Micheline Piolot Sport Cup tire (this tire is wide for a 255/40/17), I needed to roll the rear fenders for a 17X9 with 35 offset. As per above, the 29 offset will shift this out 6mm (35-29=6) and would make the rub worse.
So, depends on actual cross section of tire (assuming that the wheel vendors have measured offset properly).
Good luck.
Good luck.
dnizzle
Apr 13, 2015 09:48 PM
Curt941
25
Dec 17, 2007 08:17 AM
7m6m4
15
Jan 16, 2007 02:08 PM
