Will 16"s fit around our Brembos?
i have been wanting to rally and have noticed most people that rally use smaller wheels for more side wall i assume? anyone know if 16s will fit?
Originally Posted by tahoeacr
I have 16X5's that fit over the stock Brembo's. Three piece forged wheel. About $1,900.00 delivered from the U.K. If you really want to rally, it's cheaper to go with the Group N calipers(two pistons) and then you can run even 15's.
first there is virtually no tire selection when it comes to a 16" wheel so that gonna pose a problem.
i have a set of 15x6.5 enkei's coming in (tons of tires available for that size). your best bet is as tahoeacr said is to get group-n calipers or even (if you can find them) ap racing brakes (caliper model cp3720). they took me nine months to track down.
i built my MR into a rally car. not a rally cross car. but what would be very close to a group-n car if i were to strip it and put in a roll cage, if your interested in what i have done just respond here and ill give you a parts list.
installed:
carbon/kevlar sump guard.
wrapped lower control arms
dog eared lower control arm bolts
ralliart aluminium center bearing guard
ralliart aluminium rear diff guard
tein type hg gravel suspension
rmr intake
rmr exhaust
rmr downpipe
rmr lower brace
hks 272/272 cams
hks adj. cam gears
hks type 1 turbo timer
techno square ecu
goodridge ss braided lines
sparco harness bar
schroth 4 point harnesses
evo 9 steering wheel (couldnt help myself)
awaiting installation:
ap racing front calipers
coleman slotted rotors
pagid racing front brake pads
navigator foot rest
on order:
aluminium floorpan guard
aluminium gas tank guard
brake scrapers
enkei 15x6.5 gravel wheels
michelien (or pirelli) gravel tires
ralliart gravel acd ecu
im sure i left something out but thats the bulk of it. ive also chage some fluids and other small items that i broke or needed replacement. the next big item is gonna be a major weight reduction.
rmr intake
rmr exhaust
rmr downpipe
rmr lower brace
hks 272/272 cams
hks adj. cam gears
techno square ecu
sparco harness bar
navigator foot rest
on order:
brake scrapers
