Lubricating brake shim
when applying the high temp grease while doing a brake pad install do you guys put grease inbetween the shim and pad or just use grease on top of the shim (the part that touches the piston?)
i'm trying to get around that dreading squealing.
TIA
TIA
Originally Posted by QAT-R
Check out the how-to section on pad install. I can't remember off the top of my head but that thread is very informative.
i apply it everywhere on the backside, put a little coat on the back of the pad, and some more on the backing plate, and stuff it in there, no issues with squeeks.
(other than after a while, if i drive with the track pads on the street, they get nowhere near warm enough and i get a squeek there )
might as well get it done right the first time.
spaggiari
Nov 18, 2016 10:02 AM
Jonno99
Mar 16, 2015 03:25 PM
xbox4414
15
Sep 22, 2008 09:15 PM
