Need help with wheel fitment
I've decided i'm going to pick up a set of 5zigen fn01rc's. Hyper black, 18x9.5 +35 with 255/35/18 tires.
I've done a lot of research on these wheels, but its hard weeding out the incorrect info. So I have a couple of questions.
Will the 18x9.5 +35 with 255/35/18's work with stock suspension without any rubbing?
Will they rub at all with Hotchkis springs (36mm lower front, 23mm lower rear)?
Will I need spacers?
Do I need +35 offset on all 4 wheels, or are the fronts and rears different?
I need to use stock springs with the stock Enkei's with Blizzacks for winter. And the 5zigens with Hotchkis springs for when theres no snow. But I have to dyno tune my car soon and I can't use the Blizzacks for that. So I need to be able to just bolt the 5zigens on with the stock springs to get to the dyno and back. I'm fairly certain they will not rub with the Hotchkis springs. But would like to make sure before I order them.
Thanks.
Thanks.
the 8.5 +30 will fit perfectly - as to your rubbing, it largely comes down to your specific tire choice. Bst to search and see what tires people have had luck with in your desired size, and choose from there
FS[MidWest]: Hotchkis Springs, Stock Springs
Luckystryke
Aug 8, 2016 06:43 AM
sipevo
26
Sep 6, 2006 02:38 PM
BoostWhore
Apr 29, 2006 02:16 PM
nasa ser
12
Jan 23, 2006 01:41 PM
'ringmeister
Apr 13, 2004 07:42 PM
