Mid-corner brake oversteer?
Originally Posted by mayhem
It sounds like your application is the problem. Tapping the brakes mid corner with any car can cause oversteer.
Like said earlier, you would be surprised at the grip you get when you're on the gas with this car.
Still you need to get that alignment checked. My rear toe was screwed up from the factory.
you're coming in hot, otherwise you'd have no issue.
You're not timin yourself correctly, and if you don't see the car in front of you, when entering the corner... you're not looking far enough ahead.
I understand your point that ideally you shouldn't have to do it, but in the real world, you do every now and again.
..the guy in front misses a gear. If you're not on his *** in the braking zone, you simply don't get on the gas.
and its exactly like saying if you keep a gap, you'll never hit them. If you know you're gonna pass them, then getting up on them and late apexing it a little more will give you a cleaner line to pass.
if someone pulls out in front, and you're turning at any limit, you're screwed. you need to straighten it up and put down the brakes HARD.
What i'm saying is that you're planning for the 1% of the time, that really shouldn't ever happen. People are throwing suggestions at you that will throw your setup outta whack for the other 99% of the time, to try and counter this one.
Thats all. take care.
anyway it's 2006 and i'm drunk, and was e-mailing the boys that i'm first to enter 2006.... so anyway... you have no idea how many times this post was typed...
Originally Posted by x838nwy
I don't think the discussion here is limited to the track. So, on normal roads, things are less predictable, very much like the guy pulling out in front of you sort of thing. I know it doesn't happen everyday, but when it does happen you want the car to be as predictable as possible. Also there are times when you go in to corners a little fast, specially on unfamilar roads... I again, pretty rare, but if the car's doing something strage when it happens it's a sign that something is wrong and should be solved....
Unfamiliar roads? and you're pushing the car? not the wisest either.
Normally if it's a blind corner on the street, the speed limit is below 50. If you're doing anywhere close to the limit, car dynamics are barely even going to take effect.
Sounds like you're driving too hard, on the street, and the track.
regardless, have a happy new year.
Originally Posted by 3K
Any ideas on suspension setup or alignments to reduce this from happening?
ie. having to tap the brakes mid turn to correct the line alittle. Or in most cases so as to not bump the car in front?
Is this inherent in the stock suspension? I don't recall it doing this though. I have coilovers setup by a well respected individual so I really don't think it's the suspension but probably more likely an alignment issue?
Rear tires toeing out underbraking maybe? Any ideas? thanks
Sounds like if you are going a little hot into a turn and brake while turning, the rear end of the car swings out (oversteer.) What you are describing is basically trail braking. Trail braking is a technique that some people use to counteract understeer in a car. It is one way to get the rear end of a car to rotate more easily than it would otherwise.
Imagine that you are entering your turn with a neutral throttle and the car starts to understeer. By adding a little braking, you are transferring weight to the front tires, thereby increasing their contact patch and grip. By adding grip to the front, the rear tires have relatively less grip and the rear end will rotate (ie induce oversteer).
To answer your question, yes, this situation can be corrected by changing your suspension settings. What you really want is to get the rear end of your car to grip better. There are a number of ways to do this...
Lower tire pressures, softer sway bar settings, softer springs, softer dampening, more negative camber,
Doing the opposite of the above to the front will also increase the grip in the rear (relatively speaking).
You should talk to whoever set up your suspension and tell them whats happening and they should be able to correct things for you.
i don't think a driving technique should be corrected with a hardwired suspension change.
also trail braking doesn't make the rear end "swing" proper trail braking causes a gradual oversteer, anything swinging means you're doing things without enough finesse... anything swinging in midcorner is bad... you can swing at the beginning if you're going into something tight... but in the middle... is something you need to work on with your foot and hand disciplines.
No offense but this is my 2 cents on how I see this:
If you are having to tap the brake mid-corners often, you're likely coming in too hot (as pointed out already by fellow members). Adjust your lines/speed. For me, I set up my car to ROTATE/OVERSTEER more so that at mid-corner I can punch out/WOT as soon as possible.
If you have to tap for "emergency purposes", well then there's little incentive to correct that, right? As in, why would you want to set up your car for situations which you are not likely to encounter one corner after another?
here's another point. most evos setup to rotate have to be driven brave, that means you don't EVER tap the brake, else you pirouette, you mash the gas, bend over and hope not to kiss yer *** goodbye. so the lesson for that is... don't go in too hot, it's not as bad as in a mid engine car but it's still the same concept.
Thanks all for the replies. Enjuku teddy, Evo442 your posts were exaclty what I was looking for. I decreased the damping abit and it seems to have helped alittle. I need to mess with tire pressures next.
Also I was not coming into any corners to hot, but probably more of getting on the gas a little to early and hard on the exit side of a decreasing radius.
Originally posted by: trinydex
ha ha I like this post. This is my new mantra.
One more point, if you are braking, tapping, or reducing throttle, you are putting weight up front. If you put too much weight, then you over-burden the front tires, and they loose grip due to blow-off, rather than push. The condition is the same, but the cause is totally different.
In a decreasing radius corner, I adjust by rolling out of the throttle, you should never have to brake, at all. Worst case, I will roll out, and induce a little slide to bleed speed.
Aby@MIL.SPEC
100
Aug 19, 2015 08:04 PM
domyz
20
Oct 26, 2011 05:27 PM
