265/35/18 or 18 x9.5 offset ?
On stock suspension, will these tires fit on these wheels w/ no rubbing/rolling of fenders required?
trying to decide whether to go w/ 255/35/18 or 265/35/18 on these wheels
thanks!
thanks!
Originally Posted by JohnBradley
Taz, was this lowered? If so how much (that is with the stock MR suspension)?
No, not lowered. All stock. But a friend's red evo has black 18 9.0 35mm LE28n's with 275/35 18 hoosiers on espelir GT (red) springs. I think he's got 5 mm front spacers as well.
Have any of you tracked your cars with the 18" wheels? I'm looking at tunning 18 x 8.5 265, 35, 18 RT 615's on the street and using my stock 17's w/ slicks on the track. I'm also looking at installing some Tienne springs and a rear sway bar to take some of the snap out as you recover from a slide. Any advice?
Originally Posted by Kyle R
I run an 18X9.5 with 265/35/18 tires using an 8mm front spacer and aftermarket coilovers. Offset of the wheels is 40mm.
Im in the same boat bro. pretty much to fit that perfect sized wheel your most likely gonna need spacers up front, and all the fenders rolled depending on offset. Also from my understanding stock suspension has quite a bit of travel to it so with out stiffer spring rates you might rub. Then again youll need to adjust camber in the front to tuck the tires right. So me also deciding on this size have come to the conclusion that either buy coilovers first with camber plates, or you could get lowering springs and camber plates for the stock strut assembly before you get the wheels. anyways good luck
ended up getting 5ziegen fn10rcs in 18 x 9.5 35 mm offest with 255/3/518s, they fit perfect, no rubbing, i think the 265s would have fit with no rubbing either, once i weart these tries out, i'm getting 265s next time
FS[Northeast]: WedsSport TC105N 18x9.5 +35 with RE11 265/35/18
porsherules911
For Sale - Wheels / Tires
52
Mar 30, 2015 08:32 PM
black E
Jan 23, 2009 07:09 PM
