Hawk brake pads = garbage!
Old Jan 26, 2006, 07:36 AM
xtnct's Avatar
So according to you, pads that squeak are garbage...interesting.
My definition of garbage pads is totally different and I find that the Hawks are one of the best bang for $$$ pads out there. I did have the occasional squeak but that does not bother me.
Did you transfer the silver anti-squeal shim and pad backing from your old pads to the new ones? If not, then improper installation may be your problem. And like others said, you need to bed the pads in properly as well.
Old Jan 26, 2006, 07:45 AM
Registered User
kimletrim's Avatar
Originally Posted by jdmgalant6g72
like they said, make sure you used the oem shims, plenty of anti seize, and make sure you break them in properly.
Yes, more likely than not, the culprit for the noise is improper installation. You really need to make sure that the contact points are lubed well. I have these pads and experienced the same noise the original poster described, but I didn't go posting on how they sucked.
Rather, I took apart the brake pads again and lubed the surfaces throroughly. Now no more noise unless I brake really hard at the end of the drapstrip. I enjoy the Hawks as they brake just as well, if not better than the stocks and they dust less (less, not no dust at all).
Try taking a look at the brakes again before you go compaining about how they suck.
Old Jan 26, 2006, 07:50 AM
ch47god's Avatar
mine work exactly like superhatch, same break in and everything
Old Jan 26, 2006, 07:57 AM
justchil's Avatar
Project MU NS will squeek if not installed "properly" I love mine though. Same is probably true with the Hawk HPS pads.
Also, I find it humerous that you consider pads "garbage" without any regard to how well they perform.
I found that pretty funny too. I plan on trying these pads out when I get new rotors.. only reason I posted
Old Jan 26, 2006, 04:39 PM
BOOSTEZ's Avatar
I will take all my brakes off tommorrow and relubed. I bought the stock shims for the rear (which squeek the most) and try to reduced this noise.
What lube do I need that goes on the back of the brake shims and on the pads to reduce noise?
-M
Old Jul 17, 2006, 02:53 PM
trinydex's Avatar
these were designed in conjunction with hawk pads... so maybe give 'em a shot?
http://www.racingbrake.com/Brake_Shims_s/2447.htm
Old Jul 17, 2006, 03:00 PM
skurukutoi's Avatar
Originally Posted by vboy425
my friend have Hawk pads, they squeeke sometime. maybe you didn't install it right. Anyway like everyone said "High performance pads does make noise", you should heard one of those track car. sound like a chicken got it heads cut off.
Old Jul 17, 2006, 03:15 PM
sleet's Avatar
I have them, yet to squeek.
Old Jul 17, 2006, 03:17 PM
trinydex's Avatar
you have the racing brake ones? those are made of a dampening material... so they help damp out the vibrations that cause the squeel.
think violin string and a bow... if you have something softening the bow hairs... then it can't excite the violin string.
Old Jul 17, 2006, 03:44 PM
Danny23's Avatar
i had hawk HPS pads on my 03 8 with no problems at all, like its been said many times already you most likely installed them wrong by not using the oem hardware (shims, etc,) and anti seize.And you have to bed them correctly. try again, good luck.
Old Jul 17, 2006, 04:23 PM
fsugatorbait's Avatar
No issues here with the HPS pads after about 2k miles.
Old Jul 17, 2006, 04:26 PM
RED DEMON's Avatar
Did you get the standard HPS or HPS plus?
I have the HPS plus and they very rarely squeak.
Old Jul 17, 2006, 04:34 PM
Mulholland0132's Avatar
Not sure why you started this thread...I love my hawk pads.
Old Jul 17, 2006, 04:51 PM
BaLListic_EVO's Avatar
yeah mine squeak time to time but i have had them on the car for 40k miles! i personally couldnt be happier.. they have basically no fade and worked excellent @ my last auto-x. but they arent nearly as harsh on the rotors as stock and take forever to wear out where as the stockers went around 20k.....
Old Jul 17, 2006, 07:40 PM
Invoice EVO's Avatar
I'm running the HPS pads on the car. The only time they start squealing is when they get hot. Other than that they are fine for daily driving.
Quick Reply: Hawk brake pads = garbage!
