Best Coilovers For Street/track
i am looking to buy a set of high end coilovers for my 2006 IX MR
i mainly drive the evo on the streets as my daily driver
i want the absolute best coilover setup available, for best handling and reduced roll and pitch
i dont care if the setup is rediculously stiff and harsh, i ran 16k spring rates on my last car and didnt bother me
i do not want any kind of N1 or endurance/full race coilover setups because they require the car to be very low to the ground for the best handling results
i need the BEST street coilovers out there that money can buy, that wont require me to lower the car more than 1.5 inches.
thanks guys!
thanks guys!
http://www.muellerized.com/products.html
talk to john about your needs and he will sell you just what you need
thanks guys!
thanks guys!
If you want the best ride and handling coilovers then I would recommend the Vishnu Ohlins
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Originally Posted by chronohunter
To get a crap ride and stiffen the car up you don't need anythin near "the best coilovers" anything would do, just order them with you 16k springs.
If you want the best ride and handling coilovers then I would recommend the Vishnu Ohlins![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Moton...
https://www.evolutionm.net/forums/sh...ighlight=moton
Ohlins or KW would also be good choice.
Give us a call or email and we could help you out.
I had a set of Zeal V6 on my car with custom 12/10 springs. Its correct that you can get a high spring rate to make your car solid stiff but this is not what a good suspension is about. A good setup will need to absorb the bumps allowing your tires to stay on the ground. If you are running just high spring rate without any dampening, the car will skip over the smallest bumps which will cause a lost of traction. I would recommend Zeal X or Xs for anyone that wants to use it on and off track. If you are using it soley for tracking...go with SFR. You will be amazed at how good the ride quality is even with an ultra high spring rate setting.
Thanks,
Tom
Thanks,
Tom
huh?
wow, that is news to me.
n
Originally Posted by Spooldyou
nobody likes the TEins huh? I had my heart set on the Flexs when the Time came.
Originally Posted by GTWORX.com
Moton...
Dave
You'll understand once you get a ride in a muellerized evo.
Kw varient 3 with 9Ksprings in front and 8K in the rear. they have seperate
bump and rebound adj. plus are stainless. A 25mm rear sway bar in the rear and
some bushings makes the car.
